99 EK' Weird Starting Problem (Has to do with Fuse Box in Engine Ebay) ?
Old Feb 15, 2010 | 11:57 AM
trooper0641's Avatar
Default 99 EK' Weird Starting Problem (Has to do with Fuse Box in Engine Ebay) ?
Okay now this is first type of a weird problem that I've ever ran into and (I ran into a lot of problems in the past) and was wondering if anybody could help me figure this thing out. Ok lets see here..
Long story short.. I swapped a y8 into a 99' ek hatch. Everything went fine.. on the first try of starting it.. it turned over and puurrred perfectly @ 1,500 rpm. I shutted it off then later I tried to start it again and it wouldnt start. I then noticed that there wasnt any "CHECK ENGINE LIGHT" that was coming on and when I put the key in the 2nd position, there is also "NO FUEL PRIMING". Im like WTF!! And then later, later, I tried to start it again.. and STILL NO GO.. so I checked all the fuses and everything and noticed that whenever I try to start it.. Im getting a weird small clicking sound coming from the FUSE BOX in the engine bay itself! WEIRD **** HUH??
Anybody ever ran into this type of problem? Any information would be greatly appreciated! Thanks a bunch!
Old Feb 15, 2010 | 03:54 PM
honda.driver.bence's Avatar
Default Re: 99 EK' Weird Starting Problem (Has to do with Fuse Box in Engine Ebay) ?
clicking noise should be your fuel pump relay. maybe you need to swap the relays around to see if anything changes.
Old Feb 16, 2010 | 10:37 AM
fuel pump relay? are you talking about the main relay that's under the driver's side dash? or some other type of "fuel pump relay" located in the engine bay's fuse box or else where?
Old Feb 16, 2010 | 10:00 PM
bump for some input thx
Old Feb 17, 2010 | 12:46 AM
donutfilling's Avatar
does it start again after a while? if that only happens after turning it off on a warm/hot day then it's most likely the main relay
Old Feb 17, 2010 | 02:18 PM
its not starting at all for some reason. (no check engine light on & no fuel pump priming fuel to the fuel pump) and a "small clicking noise" coming from the fuse box in the engine bay. bump for some input help!
bnmm
Feb 19, 2011 12:07 PM
EK FLY
Mar 4, 2007 09:43 AM
Punker1234
Sep 14, 2005 01:58 PM
georgeda
Nov 16, 2003 11:47 AM
