4dr sedan hanress plug....
Old Feb 15, 2010 | 06:11 AM
crx_si-r's Avatar
Default 4dr sedan hanress plug....
ok, i am looking through my EX main harness to see how honda wired in their OEM 4 fuse slot next to the fuse box, so i can wire in all my accessories through it. but i was tracing back the wires and i am stumped as to what 1 plug is. off the 4-fuse connector i have the main power wire (White/Black) that goes into what i think is the main ignition wire...
the plug contains the following wires:
top row........[Empty][Red/Green][Empty][Red/White]
bottom row.....[White/Red][Black/Yellow][White]
now that plug i can figure it out, it leads directly to the main White/Red power wire coming off the engine bay fuse box. but what im after it this plug....
on the EX harness its right next to the plug listed above, but this 8-slot plug has me confused, i dont know what it is or goes to. it has the following wires:
Top Row..........[blue][blue/yellow][green][green/black]
Bottom Row......[black][empty][blue/white][green/black]
now the wire coming off the main relay i have a green/black wire that splices into the last wire on the plug above. What is this plug? From the looks of this wire i know it came off the dashboard because i remember it being broken before i ever took it off. next to the plug is a secondary 3-wire plug, which i thought was the dimmer switch. but after tlooking at it again im not too positive.
the 3-wire plug has these wires....[blue/red][light green/red][light green/black]
lmk if this sounds confusing? my main inquiry is that i want to know what the
on the sedans, is the dimmer switch pretty much stuck with another? u want to know what this 8-slot plug connects to. thanks in advance guys
Cpreston16
Aug 28, 2017 03:26 AM
FlewByU352
Mar 14, 2010 05:58 PM
chrisfromsrq
Jan 24, 2010 08:37 AM
silvsrt4
Oct 8, 2005 09:10 PM
RabbittZ
May 11, 2003 09:49 AM
