fuel fitting size help
Old Feb 15, 2010 | 12:22 AM
eg:R's Avatar
Default fuel fitting size help
anyone know the an fitting size that connect to the fuel filter and a str fuel rail. im trying to upgrade my fuel line to a 6an size
Old Feb 15, 2010 | 06:47 AM
DVDr's Avatar
Default Re: fuel fitting size help
Most of the system is 5/16" or people use the equivalent to -6 AN , but it seems you know that part.
Are you asking what size fitting to connect an aftermarket inline fuel filter ? or what size of fitting to install into the stock fuel filter to convert to -AN 6 line ?
Old Feb 16, 2010 | 12:16 PM
eg:R's Avatar
yes i will be running the -6an line. i will still be running a stock fuel filter to an aftermarket fuel rail. im just not to sure on the size fitting into the fuel rail and stock fuel filter hole.
Old Feb 27, 2010 | 07:47 AM
eg:R's Avatar
running a 6an to an after market rail...anyone know the fitting size on the rail??
Old Feb 27, 2010 | 07:21 PM
eg:R's Avatar
bump
Old Feb 27, 2010 | 08:33 PM
apexi_rsx's Avatar
depends on what rail your using but my BDL rail takes a 8an to 6an.
Old Feb 28, 2010 | 09:14 AM
apexi_rsx's Avatar
part number is 985068 @ anplumbing.com
Old Mar 1, 2010 | 11:52 PM
eg:R's Avatar
yes i have the BDL rail too...ill check onn the -8 an male to -6 an male...so the -8 an male fit into the rail right?
Old Mar 4, 2010 | 12:12 PM
eg:R's Avatar
does anyone know what size fitting goes into the fuel filter? im running the 95 integra fuel filter type? thanks
Old Mar 5, 2010 | 05:00 PM
eg:R's Avatar
bump
atlplayer4life90
Sep 2, 2009 04:30 PM
kbouchard1092
Aug 18, 2007 04:22 AM
Lyrikz
Sep 17, 2003 07:27 AM
senpai
Jul 20, 2003 09:40 AM
D0HC
Dec 19, 2002 01:23 PM
