window rolling up problem !!!!!
Old Feb 14, 2010 | 07:07 PM
miguey310's Avatar
Default window rolling up problem !!!!!
well my driver side window rows up side ways ,what can the problem ???
Old Feb 14, 2010 | 07:09 PM
BiG ChOr!Zo's Avatar
Default Re: window rolling up problem !!!!!
the nut probably came loose from the rail that pushes up the window...!!!
Old Feb 14, 2010 | 07:20 PM
miguey310's Avatar
oh ok and how do i fix it ??
Old Feb 14, 2010 | 07:27 PM
you place the window back on the rail and put a new nut...you have to remove the door panel...!!!
Old Feb 14, 2010 | 07:29 PM
miguey310's Avatar
do you know what size nut it is ??
Old Feb 14, 2010 | 07:36 PM
no...test fit different nuts that fit the bolt...!!!
Old Feb 14, 2010 | 07:42 PM
miguey310's Avatar
cool will try this tomorrow and let you know if it was that
Old Feb 14, 2010 | 11:39 PM
hatchet_honda's Avatar
theres actually 2 10mm bolts that attatch the window to the regulator. its proly laying inside the door somewheres. or maybe the regulator came apart somwhere on the bottom. your civic is full of those 10mm bolts. if you really needed to you could swipe on from somewheres else. ive donre it before
Old Feb 14, 2010 | 11:51 PM
miguey310's Avatar
so this has happen 2 u ?
Old Feb 14, 2010 | 11:55 PM
yes. it was one of the rollers on the lower rail of the regulator. and ive changed a broken window on my 91 dx. 2 10mm bolts hold it on
Old Feb 14, 2010 | 11:58 PM
miguey310's Avatar
so its the roller ?
Old Feb 15, 2010 | 12:05 AM
so its the roller ?
i cant really tell you whether it is or isnt...you must take off your door panel, peel off the plastic if theres any...and physical look inside the door at YOUR window and have a look. investigate my friend..see what the problem is.
Old Feb 15, 2010 | 12:31 PM
miguey310's Avatar
well i check it
miguey310's Avatar
and all the nuts seem to be there ??
Old Feb 16, 2010 | 12:29 AM
you should see 2 10mm bolt heads on the bottom of the window. check to see if the window is sliding thru the track on both sides evenly. perhaps the guide rails on the side of the window have problems
Old Feb 21, 2010 | 01:25 AM
em1effekt's Avatar
take of panel...try rolling ur window up...and see what causes the problem as your doing that....
Old Feb 21, 2010 | 01:51 AM
DCRB's Avatar
my drivers side window would roll down fine, but when i would go to roll it up the top edge would go in too far and get jammed up on the door seal. turns out my regulator was bowed... along with all four mounting bolt holes being stripped and stretched, so the whole regulator rotated back a bit causing it to roll up crooked...
Old Feb 21, 2010 | 08:04 AM
jrose152's Avatar
just replace the window regulator
phong3992
20
Mar 4, 2011 01:29 AM
Jonathan_ED3
May 9, 2005 11:42 AM
Yellb16crxsi
Mar 5, 2003 04:39 PM
SlammedHatch90
Jan 31, 2003 03:49 PM
