vacuum leak
Old Feb 14, 2010 | 09:02 AM
mengo911's Avatar
Default vacuum leak
how can i cheak vacuum leak and also if your timming is wrong will it still start up
Old Feb 14, 2010 | 10:01 AM
fcm's Avatar
fcm
Old Fart
Default Re: vacuum leak
It depends on how far timing is out.
Easiest way to check for vacuum leak is to have engine running and spray starter fluid around vacuum lines and connections, when engine revs increase you have found the leak. 94
Old Feb 14, 2010 | 10:32 AM
KWayRacing's Avatar
Be careful using this method as any arc esp from the distrutor area will be fire time. I still like using a propane torch with concentrated tip works great for finding vaccum leaks
Old Feb 14, 2010 | 03:41 PM
fcm's Avatar
fcm
Old Fart
Originally Posted by KWayRacing
Be careful using this method as any arc esp from the distrutor area will be fire time. I still like using a propane torch with concentrated tip works great for finding vacuum leaks
I have been using spray starter fluid to find vacuum leaks for a very long time and never a problem, although I have used a butane torch, [small torch I have that you plug a BIC lighter into] I did not find it as effective as the starter fluid, I have not tried with propane, I will try that next time, it would be cheap compared to starter fluid. 94
Old Feb 14, 2010 | 08:09 PM
mengo911's Avatar
thanks i'll try to do that but my car rev to 1000 to 2000 just need help and but if i cant fix my vacuum im going to sell my ej1 for 1500 come with a ls b18b1
VegasInvasion
Feb 24, 2010 05:21 PM
00gs-r
May 19, 2007 11:21 PM
ic89
Oct 18, 2006 08:24 AM
fe519
Nov 26, 2002 01:13 PM
