B16a2 oil leak
i cleaned off all the oil today and the noise went away but im scared of more oil falling on the alternator. I still cant seem to find where the leak is coming from
You can either power-wash the engine so you can see where the oil leak is originating on the clean/dry surfaces, or get an oil dye/black light kit. This is the best method to detect exactly where the oil is coming from.
I've seen a lot of unnecessary work done to fix leaks because they weren't tracked down correctly first.
If it's landing on the alternator, I would say it's coming from the driver's side rear somewhere.
Check your oil filter. It may not be tight enough, or damaged, or could be leaking from around there somewhere. That's the only thing back there that I can think of that could leak oil without a hole in the block.
I still think the valve cover is most likely, but if you say it's not leaking, I guess it's not.
mines too, but i cleaned the motor and the leak is coming from the side like where the cams are. the oil falls on the belts and throws it onto the alternator.the pic that i posted was 2 days after i cleaned the motor and the oil is falling behind the a/c compressor too. fml
diyguy13
Mar 12, 2009 05:55 AM
