B16a2 oil leak
Old 02-13-2010, 02:03 PM
honda305's Avatar
Default B16a2 oil leak
i have a b16a2 and there's oil falling on the alternator causing the belt to squeak. where can the oil leak be coming from? headgasket?
honda305 is offline
Old 02-13-2010, 03:02 PM
Meoshe's Avatar
Default Re: B16a2 oil leak
Likely it's the valve cover that's leaking
Meoshe is offline
Old 02-13-2010, 03:53 PM
Resident Gearhead
BryanM.'s Avatar
Very bad to get oil inside the alternator.
BryanM. is offline
Old 02-13-2010, 05:26 PM
honda305's Avatar
its not the valve cover
honda305 is offline
Old 02-14-2010, 01:11 PM
honda305's Avatar
i cleaned off all the oil today and the noise went away but im scared of more oil falling on the alternator. I still cant seem to find where the leak is coming from
honda305 is offline
Old 02-14-2010, 01:47 PM
New User
autotech2's Avatar
You can either power-wash the engine so you can see where the oil leak is originating on the clean/dry surfaces, or get an oil dye/black light kit. This is the best method to detect exactly where the oil is coming from.
I've seen a lot of unnecessary work done to fix leaks because they weren't tracked down correctly first.
autotech2 is offline
Old 02-14-2010, 02:05 PM
honda305's Avatar
thats what i did i washed the motor but it's coming from a place where i cannot see it
honda305 is offline
Old 02-15-2010, 08:08 PM
honda305's Avatar
bump
honda305 is offline
Old 02-15-2010, 08:24 PM
Racks On My EG2's Avatar
if oil is leaking around that area take off your alternator and try to look around it...
Racks On My EG2 is offline
Old 02-16-2010, 02:52 AM
cell445's Avatar
this is your best advice. Go to Carquest/Autozone/Advanced Auto and get some oil dye and go get a black light from Home Depot if they don't already sell one at the auto store. Let the oil run in it for an hour or so and then check for the leak with the light.
cell445 is offline
Old 02-16-2010, 05:20 AM
318 Curves, 11 miles
Vindicator9000's Avatar
If it's landing on the alternator, I would say it's coming from the driver's side rear somewhere.
Check your oil filter. It may not be tight enough, or damaged, or could be leaking from around there somewhere. That's the only thing back there that I can think of that could leak oil without a hole in the block.
I still think the valve cover is most likely, but if you say it's not leaking, I guess it's not.
Vindicator9000 is offline
Old 02-17-2010, 05:35 PM
honda305's Avatar
honda305 is offline
Old 02-17-2010, 05:42 PM
es01civy's Avatar
dunno about you but my alt is in the back of the engine...
es01civy is offline
Old 02-17-2010, 05:46 PM
honda305's Avatar
mines too, but i cleaned the motor and the leak is coming from the side like where the cams are. the oil falls on the belts and throws it onto the alternator.the pic that i posted was 2 days after i cleaned the motor and the oil is falling behind the a/c compressor too. fml
honda305 is offline
Old 02-17-2010, 05:52 PM
es01civy's Avatar
you check the cam seal??
es01civy is offline
Old 02-17-2010, 06:21 PM
honda305's Avatar
how do i check that?
honda305 is offline
Old 02-19-2010, 08:53 PM
cell445's Avatar
pull your valve cover off and take a look at the seal behind the cam gear.
cell445 is offline
Old 12-06-2011, 05:58 PM
darkcivic90's Avatar
cam seals ur problem.....
darkcivic90 is offline
Old 01-27-2022, 12:52 PM
Ashly Davis's Avatar
Front main seal behind the cranky pulley
Ashly Davis is offline
Old 01-27-2022, 01:28 PM
Global Moderator
tech8's Avatar
You're replying to a 12 year old dead thread.
Thread closed.
tech8 is offline
SathheshG
05-27-2017 03:47 PM
diyguy13
03-12-2009 05:55 AM
Serenity Now!
01-29-2007 06:31 AM
hotstuffjsn
03-09-2005 07:11 AM
mixxed
06-27-2003 07:52 AM
Quick Reply: B16a2 oil leak
