need help no start
so my car wont start.i had no spark so i changed my distributor.now i have spark but it still wont start. i am getting fuel cuz if i try starting it enough it will flood. my main relay does all 3 clicks, my cil stays on for 2 seconds then shuts off like its supposed to so its not my ecu. any ideas
it just cranks then sometimes backfired but wen it backfired i took off the dizzy and turn the crank 180 and put it back on then it didnt backfire but it didnt sound right like it was a whining crank
yea if you get backfires that means theres visible life....Such as the right components of air fuel and spark....You just need to find out which element is out of order thats preventing the motor to start....
possible causes/not enough or too much fuel-air....aka Injectors/crank position sensor?/FIRING ORDER/Timing//bad compression/a couple of bad spark plugs/maybe some bad wires/Distributor malfunction/fuel pump/votages/clogged exhaust/and any unplugged harnesses or sensor...
Most Likely your ignition timing if off...
ddn1313
Aug 4, 2018 02:46 PM
nighttrain33
Mar 23, 2008 01:38 PM
