ef b16 swap problems
Old Feb 13, 2010 | 10:00 AM
JDMmadness's Avatar
Icon6 ef b16 swap problems
so i put my swap in last week, i wired mpfi, ad vtec, my car will start but it wont stay on, and it on revs to 3k but it is running terrible, it sounds like its only running on 2 cylinders, but all four plugs are firing, im not sure if i messed up the wiring, or if it is a vacum leak, or what. anybody run into this before, i really need help
thanks
Old Feb 13, 2010 | 10:49 AM
noremorseracing's Avatar
Default Re: ef b16 swap problems
thanks
did you bleed the head and is the timing on??
Old Feb 13, 2010 | 02:15 PM
JDMmadness's Avatar
the car was in a 90 civic si a day before i put it in mine, and it ran fine
Old Feb 13, 2010 | 04:05 PM
IPimpInTheHatch's Avatar
Why did you do mpfi wiring if it was an si? Came with mpfi and are you map and tps plugs swapped? You check for vacumn leaks by spraying brake or carb clean till the idle changes. Spray all around the intake ie gaskets vacumn lines and so forth. What pins did you move on the wiring? What ecu you using?
Old Feb 13, 2010 | 04:10 PM
.Manny.'s Avatar
Touching My Member
WTF does bleeding the head mean? Recheck your wiring. Are all injectors pulsing?
ultm8mind
Northeast
Feb 6, 2011 12:51 AM
JDMmadness
Feb 18, 2010 01:43 PM
helpmycivic
Jun 19, 2009 12:21 AM
