crank pulley stuck ... cant get it off
Old Feb 12, 2010 | 08:24 PM
goldfinger93030's Avatar
Default crank pulley stuck ... cant get it off
so i need to take the crank pulley off a b16a2 ... i have the motor on the stand and already took off the bolt holding it in the center ... but it looks like the pulley is just stuck from never have been taken off before ... is there any tricks to getting it off or do i just need a bigger hammer?
Old Feb 12, 2010 | 08:56 PM
thelate1's Avatar
Default Re: crank pulley stuck ... cant get it off
So you got the bolt off, but the pulley won't slide off? Usually the bolt is the problem. Try a rubber mallet, as I wouldn't want to risk damaging the crank.
Old Feb 12, 2010 | 09:51 PM
es01civy's Avatar
use an harmonic balancer puller.. rent one at autozone
Old Feb 13, 2010 | 04:02 AM
Matt93eg's Avatar
X2, usually the bolt is the pita and whats it off the pulley will slide right off. Hope someone previously didn't tack weld the pulley to the crank. I have heard of people doing that before for some reason.
Old Feb 13, 2010 | 06:39 AM
S_F's Avatar
S_F
That pulley has never just come right off for me. I use a balance shaft puller to do it.
bradley
13
Jan 9, 2012 02:12 PM
barrera
Oct 11, 2010 07:17 AM
Riceburner247
May 30, 2004 05:58 PM
NatedoggAZ
Mar 18, 2004 08:56 AM
95lude-s
Mar 17, 2004 01:25 PM
