Different between B16B and B18CR?
Old Feb 12, 2010 | 06:30 PM
tecque's Avatar
Default Different between B16B and B18CR?
Hi Guys, im been looking around the infomation about the different between B16B engine spec and B18CR or B18C5 engine spec... Instead of Pistons, Crank size, Cam, Valves are different...
Do u guys know is there any different between Injectors, Fuel pump, Oil pump, Fuel Regulator, Thorttle body size and etc.....? Or some others different....Pls share.. i think a lot ppl would like to know...Thanks
Old Feb 12, 2010 | 07:40 PM
UncleD's Avatar
Default Re: Different between B16B and B18CR?
All the same. Crank, piston and I THINK rods are the only diff.
Old Feb 12, 2010 | 07:47 PM
95skunkedgsr's Avatar
and depending on year the cams are differnt and the head on the itr haves a slight hand porting , arnt the valves and springs differnt also?
Old Feb 12, 2010 | 07:55 PM
UncleD's Avatar
Ehh forgot the earlier itr motor. Yeah cams are a tad bit different, but all the VT is a double spring on both sides.
Old Feb 13, 2010 | 07:24 AM
siregcivic's Avatar
the b16b crank has a shorter stroke and it also has a longer connecting rod then itr, the pistons also have a higher dome then itr, buttttt.... you can find a b16b block and put itr connecting rod pistons and crank in it and people wouldnt know wtf just tell them its a b16b
everything else, oil pump timing belt tensioner water pump should all be the same as itr the cams should be the same as the 99-01 jdm itr as well
Old Feb 13, 2010 | 05:02 PM
Pinguim's Avatar
The TB´s are different in size, B16B Intake cam is a bit more agressive than the ITR one Exhaust cam is the same.
Hope it helps
Old Feb 15, 2010 | 02:24 AM
tecque's Avatar
Thanks for sharing guys.... from my find and understanding... B16B and B18cr share the same block, the crank size, rod, pistons and cams are different...this is confirmed..
Some ppl told me the TB sizes, fuel pump, oil pump, injectors and fuel regulator are different,some said same...im confused and dont know how to differentiate it...any ideas? Anyone had experiences?
Old Feb 15, 2010 | 02:38 AM
tecque's Avatar
Below show the basic differents..
Source: http://www.teirney.net/civic/B16AReference.htm
Old Feb 27, 2010 | 05:16 AM
tecque's Avatar
No one know the different?? pls share...
Old Feb 27, 2010 | 05:32 AM
00Red_SiR's Avatar
All Motor Mentor
To the best of my knowledge the TB's were the same size. The fuel pump, injectors and regulator are all exactly the same. If you want to find out the rest, just look the parts up online and see if they're the same for each model.
raverx3m
Mar 30, 2016 04:30 PM
Trust-Me
12
Jan 11, 2010 02:55 PM
ITRnorway
Aug 12, 2006 02:08 AM
mxpx035
Apr 21, 2006 09:14 AM
EK9 BEEZLER
Sep 3, 2005 01:25 AM
