to stroke or not to stroke
Old Aug 11, 2006 | 01:39 PM
ITRnorway's Avatar
Default to stroke or not to stroke
well my engine requires a rebuild now. and i am wondering if it is a good deal to stroak the b18c5/6 engine?
i found a eagle crank and rods on sale and would bore the cylinders for some fresh forged pistons
wont the stroaking change the ratio between bore and stoke? and change the character of the engine?
Old Aug 11, 2006 | 01:56 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: to stroke or not to stroke (CRXnorway)
I would probably just boar it out & get a set of "long-rod" pistons & rods from Endyn to use with the stock ITR crank. The "long-rod" setup helps the Rod/Stroke ratio of the ITR to make a little more power at high-rpm by reduceing piston speed, and the overboar takes care of the displacment to 2L...
Old Aug 11, 2006 | 07:01 PM
camlob's Avatar
Default Re: to stroke or not to stroke (94eg!)
You would still need to re-sleeve bec with the 87.2mm crank you would need 85mm pistons to bring it up to 2L. That will cost you more mullah.
Old Aug 12, 2006 | 02:08 AM
ITRnorway's Avatar
tnx for the advice/input. i guess it would be the standard crank and 1.8 FTW and just bump the comp a bit
DC2Projektz
Northern California (Sales)
May 21, 2008 09:25 AM
fmfkid250
11
Nov 29, 2006 05:58 AM
Baggy Spandex
Nov 1, 2005 12:02 PM
DEMNTD1
17
Oct 10, 2005 08:47 PM
Mike@CCT
28
Feb 28, 2005 10:09 PM
