Need Help ASAP. Running Light Relay?
Where is my running light relay. I have a 92 civic and all my lights except headlights went out. I got hazards to work again and brake lights. Changed all the fuses. But my running lights don't work still or reverse or dash lights so I need help on finding the relay. Maybe a diagram too?
So I changed another fuse again and got the dash lights working and running lights but now the passenger headlight doesn't work and the driver blinker doesn't work. It just stays on running light. HOLY CRAP this is freaking confusing!
WOW first things first. Did something happen like a major short or something?
either way: all fuses need to be checked in both fuse blocks. thats first off.
second ensure that your dimmer switch is not set all the way to low and that the wiring for the dimmer is fine. I know in my car if the dimmer is not plugged in none of the interior lights will come on.
check those things and tell us what you found out?
4serioferio
Aug 13, 2012 03:30 PM
mister_r0b
Jul 16, 2004 10:42 AM
spideycivic
May 25, 2003 03:50 PM
