1997 Honda Accord Electrical Problem????
After doing a Vtech head swap on my 1997 Honda Accord, the main wire on the alinator touched a ground and sparked.... the dash lights flash, the main relay just clicks, the speedometer and tachometer bounces when trying to start.... sometimes it will actually start but runs like crap and will not go out of gear....
I have replaced the main relay but that did not fix the problem....
I can not figure out what the problem is??????????????????
First off check all your fuses. Check FUSE 15 In the engine bay. What you did has a very good possibility that you fried the ecu, or burnt up a ground wire. So check all the grounds in the engine bar. Block, trans, and the battery ground.
But from what you are describing it sound like the ECU fried so, try swapping w/ someone once you are sure all your grounds are good.
also i got it to start and no check engine light but as soon as u hit the gas everything like the lights in the dash cluster flicker and then the car will die and u can hear the relays clicking but if u get it started and put it in gear and hit the break and gas u can stall out and everything seems just fine have no idea what else to do any help thanks everyone Tyler
OP,
Have you since tested the alternator to verify it's actually working still? Should be ~14V across the battery terminals while running.
