stutter problems
Old Feb 11, 2010 | 08:22 PM
jm_civic's Avatar
Default stutter problems
Alright its been some time since i posted so bare with me. I have a 95 dx which i did a motor swap in high school, the swap is the 96-00 jdm d15b 3 stage motor. I am running the obd1 dx dizzy and wondering if is causing problems with my stuttering problems.
Im 90% possitive its my map sensor but i just want to double check its not my dizzy before i replace it. It happens when i get low rpms and 1/2 throttle into it.
any help would be much appreciated,thanks
Old Feb 11, 2010 | 08:46 PM
raidacaipo's Avatar
Default Re: stutter problems
any check engine lights?
Old Feb 16, 2010 | 06:31 AM
jm_civic's Avatar
No check engine lights. It sounds light chewey is beatboxing in my muffler and my car losses power
Old Feb 16, 2010 | 06:41 AM
civic-one's Avatar
stuttering you have to go therapy for that but for sputter. . . it can be alot of things such as dizzy or fuel but thers more thing to it. Its better if theres a CEL but you said nothing so i cant be something electrical because they will defintely throw out a CEL. Check your wires and spark plugs are tehy still good? But once again if its really stuttering bad go therapy yo... J/K kay, but check those things. First thing id do ask a friend who has a dizzy to check and then plugs and wires.
Old Feb 16, 2010 | 06:46 AM
jhammond_82's Avatar
Reject Papi
i'd try pulling the coil out and putting a known good one in there. sounds like it may be going out.
Old Feb 16, 2010 | 07:18 AM
RotaryPWR's Avatar
ya, i'd check the ignition system starting with plugs, then wires, then cap & rotor, then coil.
Old Feb 16, 2010 | 09:22 AM
b16a95eg's Avatar
Check the Fuel filter too
fadedcrx
Oct 2, 2013 08:33 AM
rhdins
Sep 2, 2008 04:48 AM
jame2981
Jul 22, 2007 11:50 AM
jjaskula1
14
Dec 20, 2005 03:22 PM
Fiend
Dec 6, 2005 06:09 PM
