68mm tb and manifold questions
Old Feb 11, 2010 | 06:08 PM
ls_bitik's Avatar
Default 68mm tb and manifold questions
hey HT.. how big is the opening of blox itr manifold? do you think if i put blox 68mm tb will bolt on fine? i meant like do i need it to have port matched or its ok as is or stock 00 si manifold port matched and ported and polish to 68mm make better power through out the power band? which one would you guys recomend... thanks for the feedback!!
Old Feb 11, 2010 | 06:13 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: 68mm tb and manifold questions
what motor and what's done to it?
Old Feb 11, 2010 | 06:15 PM
ls_bitik's Avatar
i got lsvtec with hsl cams valve springs and retainers minor port work itr headers etc..
Old Feb 11, 2010 | 06:17 PM
00Red_SiR's Avatar
All Motor Mentor
you'll want to go wit the itr style intake and TB.
Old Feb 11, 2010 | 06:19 PM
ls_bitik's Avatar
yeh.. but which one would be better? blox 68mm with blox mani? or 68mm with 00 si port matched and polish? i have 68mm just layin around.. might as well use it.
Old Feb 11, 2010 | 06:22 PM
00Red_SiR's Avatar
All Motor Mentor
the 00si isn't the itr style.
Old Feb 11, 2010 | 11:46 PM
ls_bitik's Avatar
hahaha i wasnt askin about the itr style... b16 or blox?
Old Feb 12, 2010 | 03:25 AM
00Red_SiR's Avatar
All Motor Mentor
you were asking which manifold you should use with that 68mm TB, the b16 and blox aren't the same. The blox is basically an ITR replica and the B16 isn't, it's smaller and while good, not ideal for your build.
Old Feb 12, 2010 | 10:48 AM
ls_bitik's Avatar
ok gotcha! do you think i need to port matched with the 68mm or its good as is?
Old Feb 12, 2010 | 12:47 PM
djteggy99's Avatar
i would also like to know planning to get a 68mm onto my skunk2 manifold.
Old Feb 12, 2010 | 04:34 PM
00Red_SiR's Avatar
All Motor Mentor
you will probably have to do a little port matching for proper alignment, otherwise there will be little or no benefit.
wesley_925
Mar 22, 2008 05:06 PM
project-hatch
Sep 14, 2003 05:00 AM
EFing8
Oct 27, 2002 04:48 PM
Tru Dynamix
Jul 7, 2002 11:16 PM
Red99CivicSi
May 2, 2002 01:48 PM
