Suspension & Brakes Theory, alignment, spring rates....
Rotora drilled & slotted rotors
Old Feb 11, 2010 | 02:52 PM
tpot90's Avatar
Default Rotora drilled & slotted rotors
Recently installed these on my 6G Accord. For some reason, what looks like rust is beginning to form in the "slots" where the pad doesnt make contact. How can I get rid of this, and prevent it from getting worse?
Old Feb 11, 2010 | 03:43 PM
TunerN00b's Avatar
Default Re: Rotora drilled & slotted rotors
Perform a brake pad bedding. The heat should clear out most of the rust.
Rotors rust. That's just part of having a mild steel part exposed to the open air. The pad surface area should be cleaned up of rust by the pad itself when the car is driven, so it isn't a concern.
Maybe paint the non-contact area black? (Note, if you choose to try this, no NOT paint any of the contact surface.)
Vagitarian
Jun 20, 2013 03:16 PM
ZAKU
Mar 1, 2008 06:24 PM
mobstersmoke
Jul 28, 2004 09:55 PM
Marcos
Jul 21, 2004 11:45 PM
Marcos
Jul 20, 2004 06:51 PM
