how do i get access to back of door panel?
Old Sep 6, 2002 | 07:51 AM
serious's Avatar
Default how do i get access to back of door panel?
could some please explain to me how to pull the inside of my door of so i can get access to the inside of the door panel? i want to get the dings out of my door.
Old Sep 6, 2002 | 09:32 AM
raene's Avatar
Default Re: how do i get access to back of door panel? (serious)
Do this:
<ul>[*]Remove window crank handle (ya know, the thing for your windows... sorry, just woke up). You do this by pulling out the C-clip from underneath it. Get in there with a flathead screwdriver, you can do it. Next pull off the window crank and the plastic washer.[*]Remove doorhandle. Do this by lifting up the handle like you're opening the door from the inside, then removing that screw that's visible & saving it. Now set it aside, unlock the door (should already be unlocked, but whatever) and pull the plastic cover around the handle off while holding the handle open. It's a little tricky but not rocket science.[*]Remove the single screw from the little handle you use to close your door (the one that's integrated into the armrest). Wiggle the little plastic cup until it comes free - it's clipped into place. [*]If this is the driver's side door I believe there's also some screws in the bottom storage box that need to be undone. Please do so.[*]There should be a screw or two on the part of the door nearest the back of the car - the back edge. Please undo.[*]Now the door panel should be basically free. Starting at the bottom, work your hand underneath a small bit at a time. Finally the door panel will snap free - it's held in with retaining clips. Just keep yanking those out one at a time until the bottom is loose. Now lift the door panel straight up into the air - this will pull it off the actual metal door piece - and out. [/list]
That should be it
One final note: the door interior is covered by a plastic sheet. I'm not sure how you'll get that off there and then reattach... I don't think silicone works.
[Modified by raene, 10:33 AM 9/6/2002]
Old Sep 6, 2002 | 03:16 PM
Timmah!!'s Avatar
Default Re: how do i get access to back of door panel? (raene)
Do this:
You should be able to get that clip out by sliding a rag through it
Old Sep 6, 2002 | 03:52 PM
dustin's Avatar
Default Re: how do i get access to back of door panel? (azroth)
Usually door dings are in the center of the door, and there is reinforcement metal there.. So even if you take the door panel off you won't be able to get the dings out most likely hehe.
APEX CRX's Avatar
dude you need to buy a factory repair manual, don't leave home without it
Old Sep 6, 2002 | 03:56 PM
dustin's Avatar
Default Re: how do i get access to back of door panel? (APEX CRX)
I actually have the '88 CRX service manual in PDF format if people want it. Someone posted it up a while ago.
Old Sep 6, 2002 | 04:40 PM
USDM 4G VTEC's Avatar
Default Re: how do i get access to back of door panel? (dustin)
and as a matter of fact, i wantd to take the door black trims to paint them today and the reinforced metal on the inside of the door wouldnt let me take the mold out....sucks...... i had to take and paint the plastin on the car.....
businessmanph
Oct 30, 2005 10:45 PM
206civic
Jan 8, 2005 11:43 AM
JDMEK206
Jun 27, 2003 02:36 AM
1997exciv12w3
Sep 3, 2002 05:12 PM
