oil cooler???
Old Sep 5, 2002 | 11:50 PM
thaiphob's Avatar
Nikon!!!
Default oil cooler???
has anyone installed an oil cooler in to their crx??? what are the benifits/downfalls (if any). pics and instructions would be most apriciated !!!
Old Sep 6, 2002 | 01:14 AM
88civic's Avatar
Default Re: oil cooler??? (thaiphob)
they help alot any time you can keep the oil temp around 180-200* the better but dont make the lines too big or you will be running low oil pressure the pump cant handle it and oil will just sit in the lines and move slowly then poss. spin a bearing...dont have pics but known of it done but have seen it done.. also you can heat wrap your header where it goes under the oil pan it will help keep oil temp. down too.
good luck..
Old Sep 6, 2002 | 08:44 AM
1QWKCRX's Avatar
Default Re: oil cooler??? (88civic)
Becareful with thermal wrap. Its a good idea, but they trap moisture and can cause premature rusting on your headers!
Old Sep 6, 2002 | 10:49 AM
Steve91's Avatar
Unless you race the car, there is a no need for an oil cooler. Your first step would be to install an aftermarket oil temperature gauge to see what your temps are. If their below 240, your fine.
Old Sep 6, 2002 | 11:08 AM
thaiphob's Avatar
Nikon!!!
thanx for the info guys. i will try the temp guage and take it from there!!!
Old Sep 6, 2002 | 06:56 PM
travis's Avatar
downfalls (if any)
Reasons not to:
-expensive
-more prone to failure/leaking
-requires more oil
Reasons to:
-easy install of accusumps, temp/pressure gauges, oil thermostats, etc.
-keeps oil cool (duh)
-quick filter replacement (with remote filter)
Old Sep 6, 2002 | 06:58 PM
ijjz's Avatar
Default Re: oil cooler??? (Steve91)
Exactly what I was going to say. No point if you are not going full race.
Old Sep 6, 2002 | 08:29 PM
thaiphob's Avatar
Nikon!!!
thanx for the imput!!!
Old Sep 6, 2002 | 09:00 PM
Loco Honkey's Avatar
I'd have to say that if you have a turbo, it's worth if if you want it. Not nessicary, but it'll help in the long run.
Old Sep 6, 2002 | 09:02 PM
johnzm's Avatar
Default Re: oil cooler??? (F=WT)
i have read if you do install an oil cooler into a street car it might keep the oil tooo cool. ther are tempreature controled valves u can get for an oil cooling system if u do decide to do it. i suggest u get those
Old Sep 6, 2002 | 09:05 PM
Default Re: oil cooler??? (johnzm)
You've read. Do you have any actual experience?
Again- NA street cars, nah... turbo street cars, yah.
Old Sep 6, 2002 | 09:28 PM
ijjz's Avatar
He has a point, that would be the only exception. But even at that, you do not necessarily need it to run good. Money could be better well spent some where else IMO.
Old Sep 9, 2002 | 09:25 PM
thaiphob's Avatar
Nikon!!!
Default Re: oil cooler??? (ijjz)
good point
Old Sep 11, 2002 | 01:34 PM
LonelyDriver02's Avatar
Hey guys, yeah i plan on making myself an oil cooler as well for my turbo civic. check out this one http://store.summitracing.com/global.../prm-12311.jpg its got its own fan. here's a good site that shows how to install one on ur own too http://tech.hybridgarage.com/tech/oilcooler/
Austin
Dec 31, 2017 02:56 PM
90crxzc
Dec 6, 2003 01:36 PM
Screamer
May 14, 2003 11:35 AM
