HOW TO CLEAN EGR PORTS????
Old Feb 7, 2010 | 08:36 PM
bromozee's Avatar
Default HOW TO CLEAN EGR PORTS????
MY 01' ACCORD STUTTERS SOMETIMES. I CHANGED THE PLUGS AND WIRES, BUT IT STILL DOES THE SAME THING. MY MECHANIC SUGGESTED THAT I CLEAN THE PORTS. IS THERE ANY INFO, DIAGRAMS, WALKTHROUGHS, OR VIDEOS THAT CAN HELP??? thanx
Old Feb 7, 2010 | 10:02 PM
bopbop93030's Avatar
Default Re: HOW TO CLEAN EGR PORTS????
Check the FAQ.
I think that the location of the EGR port of your engine is similar to the ones for 90-97.
Old Feb 8, 2010 | 09:01 AM
punkassd's Avatar
assuming you have the f22 or a 23 motor.. find your egr valve. when looking at your engine it should be to the left of the fuel rail. to clean the ports you will need to remove the fuel rail. under the rail there is a aluminum egr runner "compartment" is what id call it. it will be held by about 4 bolts that attach it to the intake manifold. take it off and open it up and clean it out. underneath this compartment will be 4 holes that lead into the intake manifold. alot of times they will be completely carbon locked. so break out a small drill bit or really thin chisel/screwdriver deal and clean that crap out. buy some carbon cleaner spray it around in the runners to help. you should replace the gaskets so you dont have leaks in your egr system if you dont you could run into a vaccum leak later. use a shop vac to suck up the as much carbon as you can. the carbon that gets down into the intake is not a huge issue as it will pass or burn up through the combustion process. hit me up if you need more help.
Old Feb 8, 2010 | 02:02 PM
VTECn83's Avatar
http://www.tegger.com/hondafaq/tsb/accord/A99-085.pdf
http://www.freewebs.com/hondadude/95...5AccordEGR.htm
http://home.comcast.net/~em-engineering/T2T013.pdf
Old Mar 18, 2010 | 06:36 AM
BobS95v6's Avatar
I'm new to this forum trying to extend the life of my 95 Accord V6.
Any diagrams or photos detailing this procedure for 95 V6, C27A?
Old Mar 18, 2010 | 08:47 AM
92civlude's Avatar
The F23 does not have an access plate or EGR plugs on the runners. The plunum has to be removed. With the upper plenum removed, as youre looking at the engine, the egr port is on the left side of the lower intake. Clean it out with carb cleaner. Clean the upper plenum as well.
Old Mar 18, 2010 | 10:28 AM
BobS95v6's Avatar
I'm looking for instructions on cleaning EGR port(s) on the '95 C27A engine, a V6 2.7 liter, not a F23 4 cylinder.
Old Mar 18, 2010 | 10:41 AM
92civlude's Avatar
What engine do you have?
Old Mar 18, 2010 | 10:43 AM
92civlude's Avatar
Hey bro. Dont hijack this dudes post.
Old Mar 18, 2010 | 11:13 AM
BobS95v6's Avatar
What's the big deal? The thread is discussing EGR ports, I can't start my own thread for another 15 days, this gives me my 4th post and I ain't your Bro. I didn't make the rules. Chill.
Old Sep 6, 2013 | 07:30 AM
txusa03's Avatar
great info! This look like something i can do at home for my 1994 accord. Thanks.
H22 CB
Dec 7, 2016 12:57 AM
arielb1
Apr 15, 2016 03:20 AM
361 accord
Mar 21, 2007 04:34 PM
mikeunreal
Jan 15, 2006 11:44 AM
Xtian8
May 24, 2004 07:18 PM
