Questiong about cleaning my IACV...
Couple things. Im about to clean out my iacv beacuse my car idles real hard, might be the culprit. I use carb cleaner correct? Secondly, when i take of the 2 bolts and pull it away from the block, do i need to disconnect the 2 hoses to clean it or can i just spray some **** in the screen area and just let it dry for awhile? THanks
Mike
Mike
Carb cleaner, yes
Remove the 2 bolts and pull it from the intake manifold
Might as well undo the coolant lines so you can clean it better
While youre at it, clean the connector and put dielectric grease on it
