Help removing crankshaft timing belt gear
I've nearly got the crank out, but I need to remove the crankshaft gear - its keyed onto the end of the crank (the timing belt is driven by this gear). In theory is should slide/pull off but nothing so far. There is no room behind it for a gear puller, just a thin (and now mangled) washer. Prying with various instruments of destruction has resulted in nothing. I swiped someone else image of this gear. Next is the blow torch on this sucka. Thoughts? Thanks.
j4s0n1337
Feb 15, 2012 03:07 PM
