OBD0 pinout questions...
i got a 1990 ef hatch (DX)
i recently did an auto to stick swap and swapped in a DOHC ZC and im relooming and fixing corroded connections and wires in my engine harness(1990 DX mpfi'd with cam sensor wires for ZC)
i came to find a wire is cut..(yellow) it runs from pin "A8" on ECU plug connector "A" can anyone tell me if i need this wire in my new setup(1990 dx hatch DOHC ZC) that was converted to stick?
i looked it up and it says tranny lockup selonoid and i understand thats only for auto trannys
the yellow wire runs through the drivers side round connector and to the looming that comes out to the head temperature sensors and dizzy plugs and 02 sensor...
Hondasaurs
Nov 27, 2002 02:00 PM
