Replacement of Power control Switch and keyless entry doesnt work
Ok, so my drivers side window would work on and off and It really bothered me. I actually went to my uncles shop and picked up an extra window switch that he had and everything seems to be better as of now however; my keyless entry does not work. I am sure there has to be some correlation between the locks on the drivers side switch and the keyless entry. Can anyone please help me. I am stuck without keyless entry. Thanks a lot
We need some more information on the car (year,model,and trim level). Most newer honda all have integrated multiplex in the master window switch.
This is a 2003 Honda accord Ex. I dont hear any sound at all. I mean I actually twice already lost myself by walking away from my car and pressing buttons on it. then havin to come back and lock it with the key manually.
This is a 2003 Honda accord Ex. I dont hear any sound at all. I mean I actually twice already lost myself by walking away from my car and pressing buttons on it. This is a 2003 Honda accord Ex. I dont hear any sound at all. I mean I actually twice already lost myself by walking away from my car and pressing buttons on it. then havin to come back and lock it with the key manually. The car is in good condition and until I had problems with the window, everything seemed to work just fine havin to come back and lock it with the key manually.
Will the locks lock with the power swich inside the car. While the window switch you picked up may look and install like the old one it is important that it was from the same exact vehicle as yours was. Have you tried reprogramming your keyless? Look here to do that https://honda-tech.com/forums/honda-accord-crosstour-2003-2012-118/key-fob-not-working-2682417/ Post back
It is very important that you use the right switch as stated above. Sounds like either you need to be programmed, or you have a door lock actuator at fault.
You need Honda Part# 35750-SDN-A12 retails for $174.00, that is if thats problem.
Saif Jonz
Jan 14, 2017 09:02 PM
xsean415
Oct 30, 2005 04:47 PM
