How many went 2L B series?
I know there are some out there that have either gone with a B20 block or sleeved/bored the block to a 2.0. I would just like to hear some setups and comments about it using the all the Type R stuff just changing pistons or something because of the larger bore
"I would just like to hear some setups and comments about it using the all the Type R stuff just changing pistons or something because of the larger bore"
i don't understand what you mean!
but anyways i went 2.0l b18c5 just because i wanted my original motor on my car and i like looking at my motor and seeing b18c5!LOL! but doing a b20 actually will probably be better because first of all its cheaper and secondly you can safely go 2.2l by sleeving. a 85mm by 95mm bore/stroke would give you the correct displacement. Mike L from Kingmotorsports actually used a b20 on his 282whp 11sec hatch with a 85mm by 95mm setup. either way you go b18c5 2.0l or b20 you'll probably put down the same numbers! I went 84 1/2mm bore with a 89mm crank(pretty much a ls crank)
What I meant by using the Type R stuff is the B18C:5/6/R bottom end internals besides the pistons and using the full top end. Whether you sit a B20 block on there or sleeve and bore a 1.8. I guess I'm just curious about how it would run since tonight was my 1st Honda big block experience and damn it ripped. I'm not going to sell my B18CR for a H22 lol that would be *** backwards but I was thinking more displacement and keeping the higher revving and higher compression would make it potentially run a lot stronger than a H22.
Boost or N/A, your going to spend a lot of $$ regardless. This is an issue I just can't make up my mind on. Been considering the B20/vtec thing for a while but really not sure what to do. The car's been down for a while so I can start from scratch.
I'm confused at what you mean. The H22 ripped, it was fast, it would walk my R. I want my car to feel like that, actually being pushed back into the seat. I'm sure the B18CR would be pretty damn quick in a EG hatch but considering my car is what 2500 or 2600lbs I need a bit more power to make it feel like that H22 hatch. The whole point of this thread was to hear about peoples experiences with a 2L B series Type R. more displacement seems like the way to go.
Well I know that Hyrev2nr have talked about the crvtec setup, but he doesn't know that my setup is done.
B20 block- cp pistons, eagle rods
ITR head- supertech head package.
RMF narrow header, test pipe, BCIII exhaust
Blox bpi
Stock cam
206 whp on dyno dynamics
Blox bpi
Stock cam
make that x3. I have respect for the K series. No doubt it will push out some very impressive numbers. However its not for me. If I had a car with no motor and the choice to do a B18CR or a K20AR both the same price for it to be complete I would go with the K. IDK what it is I love the B series though. Back on topic I just want more power out of the R and I know its going to cost me. I figure getting more displacement would give me better results though. I wanted to go turbo and still want a turbo car, but the thing is anything turbo can be made fast. Think of how truely amazing it is to be making 110+ HP per liter all motor. Not many car manufactures can say they have done that without the use of a turbo. Ferrari has done it time and time again but look at how fine tuned and what a work of art those are. Then to be a B series that gets down? Power per $ boost is cheaper, but if you dont top the lower end motor whats the point of having your motor? Catch my drift? D series turbo at a reliable power arent all that up there. If you made your B series around the same power what was the poin of having the B series? Same with the K. Now what all motor D series can make over 200WHP? I've seen 1 ZC that Spoon built do it and that was it.
EK SQUAD 425
Sep 18, 2007 06:48 AM
Suprdave
23
Mar 23, 2005 05:12 AM
TypeR0149
Aug 22, 2001 12:32 AM
