i need help with my dpfi to mpfi swap
Old Feb 6, 2010 | 04:18 PM
wagooovan91's Avatar
Default i need help with my dpfi to mpfi swap
i am doing my car multi point fuel injection and i bought a full engine harness out of a 91 ex four door civic i have the resistor box injectors intke manifold everything is on i just need to know how to wire it up can someone please help asap my block is a d15b2 my head is a z6 vtec and my car is a 91 civic wagon
Old Feb 6, 2010 | 05:04 PM
pearl95sc's Avatar
Default Re: i need help with my dpfi to mpfi swap
The EX 4dr engine harness won't help get your vtec up and goin, did you have plans for an obd1 swap or a shift light/throttle switch style vtec engagement?
Personally i've don't the dpfi to mpfi swap and added the wires from the ecu to the engine. Maybe some others can comment as to the interchange on the engine harness' from the DP injection to the MPFI.
Old Feb 6, 2010 | 09:37 PM
D16SiHatch's Avatar
you need to use your stock harness and convert it to mpfi. you can't just drop in an engine harness thats mpfi unless the car was mpfi to begin with. the extra wires for it are not present in a dpfi cabin harness.
http://hondaswap.com/swap-articles/d...writeup-49557/
for vtec to work how it was intended you need to convert to obd1 and run a p28 or some other chipped ecu with a p28 basemap. once you do the conversion you'll be able to use this.
http://rywire.com/store/8891-crxcivi...6bfb1a6b8e9f70
Old Feb 8, 2010 | 12:38 AM
what color is the ignition output signal wire cause im throwing a code for that but my car is running now just not the best yet
Andy Falkowski
Feb 8, 2016 02:52 AM
tgdrums1990
Jan 22, 2014 04:21 AM
PaChiLa Leader
Nov 8, 2008 10:52 PM
DOHCintegra91
Sep 24, 2006 08:29 AM
JDM97typeR
Feb 18, 2004 11:14 AM
