Think I ran my 255 LPH fuel pump dry..
Old Feb 4, 2010 | 07:23 AM
High Boost's Avatar
Default Think I ran my 255 LPH fuel pump dry..
So, Back is sept coming home from my girlfriends house, I was low on gas, and when I got home I put the car in the garage, it sat for a while (big no no) and couple days later I started it up and make a chunky kind of sound. My spark plugs were bad. I didnt have time to go out and get new ones, so I used a set that were in still good shape. I only installed 2 to see if that was the problem. Started up and the noise went away. Then it sat for a while after that, and then one day I went to start it and started up perfect and went to get gas for it and just about filled it up. A month or so goes by, and went to start it up and it had all it could do to not stall and then it did and shut off. Now it wont start. Iam going to pick up new spark plugs hopefully today or tomorrow and hopefully it will start. If not, do you think its the fuel pump that went bad and need another one?
Thanks in advance!
Old Feb 4, 2010 | 07:25 AM
kyden's Avatar
Default Re: Think I ran my 255 LPH fuel pump dry..
do you hear the fuel pump turn on when you cycle the key?
Seatown
Nov 14, 2006 06:51 AM
Marcpb443
Jul 16, 2006 08:59 PM
patrick4588
May 26, 2006 03:14 PM
lawlerlaw
Nov 16, 2004 01:25 AM
Daniel_san
18
Apr 26, 2004 06:24 AM
