a little guidance from an expert
Old Sep 5, 2002 | 04:40 PM
tyler's Avatar
Default a little guidance from an expert
just got a zc motor with a broken cam, it doesn't appear to have done any damage to the vavles, pistons, etc. but would appreciate some advice on what to look for, or double check before proceeding with a new cam
Old Sep 5, 2002 | 05:35 PM
SPORT INJECTION's Avatar
Default Re: a little guidance from an expert (tyler)
If I knew anything, I would help you. I don't know ****.
Old Sep 5, 2002 | 09:02 PM
b19coupe's Avatar
Default Re: a little guidance from an expert (99MilanoRedSi)
Check the cam journals-did the cam sieze in the head? The head may be junk. Cams break for a reason. Oil starvation?
Old Sep 6, 2002 | 12:08 AM
riceboy's Avatar
Default Re: a little guidance from an expert (b19coupe)
pull the head off, take it to a machine shop, they can magnaflux it and check the head for damage of any sort.
Old Sep 6, 2002 | 04:02 AM
hondafrk's Avatar
I'll have to agree with this one, I seen an accord one time that had a timing belt break and when I went to repair it I was trying to turn the cam back to the proper postion and It was froze up. Ended up pulling the cam off to find out the cam journals were completely destroyed, Had to buy a new head, Things got really expensive really quick.
Old Sep 6, 2002 | 06:25 PM
XKWISIT1's Avatar
if the engine is unassembled you could do a leak down test to see if you have anything leaking, like rings or valves
journeyquest
Jul 11, 2011 10:58 PM
new_climber
Jan 16, 2009 05:27 AM
99blusi
Jul 25, 2005 06:01 PM
