Shifter moves as it engages in gear
Old Feb 2, 2010 | 05:00 PM
ef yu's Avatar
Default Shifter moves as it engages in gear
okay i know it sounds dumb and of course the shifter moves when its in gear and the gas pedal is pressed, but the thing is, mine move drastically. like enough for the shifter to hit the console. eeeek!!!!!!!!!. i also notice a bit of loss in power as well.
has anyone ever had this problem? i installed a short shifter about a month and half ago. this problem just started today.
Also noticed a bit of oil leaking somewhere underneath my tranny casing. =( .
Could my tranny be done ?
Old Feb 2, 2010 | 05:05 PM
D16SiHatch's Avatar
Default Re: Shifter moves as it engages in gear
if its moving that much you should check the shifter itself and also your rear tranny mount. the oil leak could be coming from numerous places. you'll really have to get under there and look hard to figure out where the leak is originating from.
Old Feb 2, 2010 | 05:21 PM
ef yu's Avatar
going to put it on jack stands tomorrow morning and see whats up. i just hope that my transmission isn't toast.
Okay nevermind guys. lol my rear engine mount had taken its toll and broke on me. luckily i was a block away from home when it happen.
had a solid engine mount. guess im going back to inserts.
9818tegr
May 5, 2022 06:49 AM
SisterFister
May 31, 2010 10:47 AM
snzh22
Aug 19, 2007 09:51 AM
rasta420
Nov 25, 2004 09:57 PM
pogichinkyguy
Honda S2000
Apr 27, 2004 03:15 PM
