Need Help Finding where does this Air tube goes on the Manifold!! help!!
Old Feb 1, 2010 | 08:49 PM
OMGdjdy's Avatar
Default Need Help Finding where does this Air tube goes on the Manifold!! help!!
i just got this Car its a 95 integra SE with b18b , can you help me find where these 2 air tube goes one is on top of the throttle and one is on the top right side of the the intake manifold i found it hanging and its sucks air but i look and look and found no place to hook it up.... i have pictures below
please help! thanks
Old Feb 1, 2010 | 10:16 PM
zedron's Avatar
Default Re: Need Help Finding where does this Air tube goes on the Manifold!! help!!
I cant remember where they went exactly because my car has not been anywhere near stock for some time. I know I have the one on the throttle body blocked off. Try to take a pic of the back on intake so i can see hose better.
Old Feb 1, 2010 | 10:40 PM
worlds-slowest-EG's Avatar
the one on top of the tb goes to the charcoal canister. not sure of the other one
Old Feb 2, 2010 | 12:00 AM
OMGdjdy's Avatar
the one that sucks air is the one that concerns me because my idle is high right now i think due to sensors or air leak(i clean FITV and iac and throttle) and when i block the tube from the manifold from sucking air the rpm drops down which i dont it it is a good thing or bad thing but in my case is a good thing because i hate how its idles i just need to find where to put it i try looking at motors pictures but i cant quite find the other end
Old Feb 2, 2010 | 12:57 AM
seanbev24's Avatar
I'm not that familiar with b18b manifolds but the other one looks like the evap purge solenoid, which also goes to the charcoal canister. If you're not worried about a visual emissions inspection you can just cap it all off.
Old Feb 2, 2010 | 07:04 AM
OMGdjdy's Avatar
thanks i appreciated its
SovXietday
Welding / Fabrication
34
Feb 28, 2014 04:02 AM
james007
May 26, 2010 06:32 PM
alfaaay
Jul 13, 2005 01:07 AM
GruvyTune
Apr 10, 2005 02:10 PM
JbJc7703
22
May 2, 2004 09:41 AM
