Golden Eagle Intake Manifold - Please answer....
Old Apr 9, 2005 | 03:46 PM
GruvyTune's Avatar
New User
Default Golden Eagle Intake Manifold - Please answer....
Anyone have one they can look at for me?
I have mine mounted on my prelude.
The IACV mounts on the back, upside down from how it mounts on the stock manifold. I am concerned about how this valve can possibly work like its designed to. There are 2 air ports. one should open into the body of the manifold and the other normally gets routed to before the throttle plate on the throttle body in order to allow bypassed air into the intake.
I clearly remember that there was no air tunnel coming to the mounting flange for the throttle body so how can this function?
thanks
Old Apr 9, 2005 | 04:05 PM
HYBRID_H@TCH's Avatar
Default Re: Golden Eagle Intake Manifold - Please answer.... (GruvyTune)
I have never seen a GE manifold..but it may have a tube inside that vents out the back for by-pass air..I have seen some manifolds like this and you just use a little air filter on the tube that hangs out..
Old Apr 9, 2005 | 04:17 PM
GruvyTune's Avatar
New User
Default Re: Golden Eagle Intake Manifold - Please answer.... (99Hybrid_Hatch)
no
no vent coming out the back. only vacuum lines and brake booster line
Old Apr 9, 2005 | 05:35 PM
project dc2's Avatar
theres a vac line right under the IACV port. thats where it gets the fresh air from. leave it open.
Old Apr 9, 2005 | 05:52 PM
GruvyTune's Avatar
New User
wow
cant believe I missed that!
thanks for the help...
Old Apr 10, 2005 | 02:10 PM
GruvyTune's Avatar
New User
so,
needless to say, me iacv works fine now.
however, i am still plagued by a stalling idle when i come to a stop. i took out the lightweight flywheel thinking this was the problem. I've run into this with other turbo'd and modified cars but i have yet to figure out how to resolve this completely. fuel and timing changes dont seem to do it.
any ideas on this one? seems to be a common problem encountered by others as well.
thanks
Tong.Y
Engine Management and Tuning
Nov 18, 2009 03:33 PM
alfaaay
Jul 13, 2005 01:07 AM
GruvyTune
Apr 10, 2005 02:08 PM
b16hybrid2
Jun 10, 2003 05:46 AM
trbob16a
Jun 21, 2002 02:37 PM
