need some clutch advice
Old Feb 1, 2010 | 04:01 PM
A.R's Avatar
A.R
Default need some clutch advice
ok so ma stock B18C clutch has done its time now.
wanna replace it with a worthy upgrade.
my current set up is:
B18C gsr
R- cams
R- ECU
Skunk2 IM
everything else stock
looking to upgrade exhaust though
So wat are the performance clutch kits u guys recommend??
this is my DD btw.
so far im thinkin ACT, Exedy, ClutchMasters.
wat are some of u guys running?
Old Feb 1, 2010 | 04:07 PM
GagnarTheUnruly's Avatar
Default Re: need some clutch advice
Exedy Stg 1 or OEM if you want to save a little $
Old Feb 1, 2010 | 04:21 PM
A.R's Avatar
A.R
lets say im not on a budget :-)
not looking a full race kit though
looking a nice performance upgrade from stock, plan to do a bit of drag once in a while.
Old Feb 1, 2010 | 05:06 PM
dothacker's Avatar
stage 1 since you dont have any heavy mods.
Old Feb 1, 2010 | 07:09 PM
dalejrfan88's Avatar
I have a competition clutches stage 2 clutch in my DA. Its about as heavy of a clutch as i would want to go for daily driving. I do plan on going turbo in the near future so that is why i have it.
Old Feb 1, 2010 | 07:58 PM
ARdb8's Avatar
+1 exedy stage 1.
Old Feb 2, 2010 | 04:37 AM
S13Morgan's Avatar
What about those F1 racing clutches? I have seen those listed on some peoples mods lists and they are super cheap also. Does anyone have experience with them? I'm thinking that i might buy one of the F1 clutch kits that comes with the lightened flywheel also.
Old Feb 2, 2010 | 07:26 AM
A.R's Avatar
A.R
ok im thinkin about the Clutchmasters FX300.
wat u guys think?
anybody running this?
Old Feb 2, 2010 | 11:59 AM
Schister66's Avatar
Man U FTW
I saw that you had listed Exedy in your original grouping. May i suggest the Exedy stage 2 Cerametallic. I ran that for almost 2 years in my GSR and it held firm at 315whp/216wtq. When i removed it, you could hardly notice the wear. It was a very streetable clutch as well. I daily my GSR so that is a big factor for me...Its worth checking out
Old Feb 2, 2010 | 12:18 PM
95 integra's Avatar
OEM
Exedy Stage I or ACT (HDSS or whatever they call the new one)
No need to get all fancy for 170whp....unless you have cash to burn, inwhich case you should get the exedy or OS Giken super single.
Old Feb 2, 2010 | 12:41 PM
Schister66's Avatar
Man U FTW
The only reason i would step up to something beyond an Exedy 1 or other OEM spec clutch is because they are organic plates. I would rather use something ceramic/cerametallic because, although they may be a little harsher, they will tend to last longer. They are also significantly harder to heat damage/ glaze.
Old Feb 3, 2010 | 05:47 AM
S13Morgan's Avatar
Anyone have or know anything about the F1 racing clutches and flywheel, or have experience or anything at all with them?
Old Feb 3, 2010 | 04:32 PM
A.R's Avatar
A.R
can i run a stage 3 clutch kit in my b18 box safely without any issues??
Old Feb 3, 2010 | 04:56 PM
bombjester's Avatar
i just got a new clutch kit and I got the exedy OEM it was cheap so if you just want to replace it...
i think later stage kits will be harder to drive too for everyday use
Old Feb 3, 2010 | 06:24 PM
1StepConcepts's Avatar
went with a exedy stage 2 since stage 1 is like oem... just incase i wanted to upgrade anything for the future.. i dd my car too its comfy enough for me.. and also went for a 8lb carbon flywheel too since the tranny was off.
hope that help.. good luck with the search..
Old Feb 3, 2010 | 08:14 PM
icucnme's Avatar
competition clutch stage 5 "4 puck sprung hub with heavy duty pressure plate"
Not much stiffer then stock but grabs like no other. I dd the car also.
Old Feb 4, 2010 | 04:27 AM
A.R's Avatar
A.R
thanks for the responses guys
seems alot ppl go for Exedy stage 2.
anybody here running clutchmasters??
Old Feb 4, 2010 | 04:34 AM
OH_1fstgsr's Avatar
I ran an ACT HDSS Clutch on my GSR for 80,000 miles. The car made between 160-185whp during that time. It failed, three of the damping springs blew out of the friction plate.
I now run an Action 1MS clutch. On off feeling and less petal effort needed than the ACT, closer to stock. Very nice piece and I like it so far. I have only had it on the car for 250 miles.
Old Feb 5, 2010 | 08:14 AM
icucnme's Avatar
I ran the same clutch in my dohc ef for 3 years with no problems and I beat the **** out of it.
I had a clutch masters in my first car and I liked it but only ran it for about a year.
I'm a comp clutch guy. Had one in my last car and now this car. Btw the guy who owns comp clutch used to work for clutchmasters and started his own business. Same stuff just cheaper priced.
Old Feb 5, 2010 | 08:18 AM
OH_1fstgsr's Avatar
Why does everyone keep listing years on a clutch? Please list the miles.
The 80,000miles on mine was over 6-7 years.
I also beat my ACT pretty hard, over 200 runs down the drag strip power shifting.
Old Feb 5, 2010 | 09:09 AM
I've got maybe 50k on my Exedy OEM and it's fine. I expect it to keep going for a while longer.
Old Feb 5, 2010 | 04:36 PM
Muskie Man's Avatar
I would say OEM or Exedy stage 1 would be enough for less than 200whp. When I put my b18c5 in my '92 GSR I used an OEM honda clutch. I was still able spin the tires like mad into second gear and could still chirp em easily going into third gear with the OEM GSR clutch. I still havnt worn out that OEM clutch at way over 60k but plan on upgrading to Exedy stage 1 with matching Exedy flywheel. The stage 1 is supposed to handle a 20%+ increase in torque. It is very difficult to make more than a 20% increase in torque without boost in these motors.
Old Feb 8, 2010 | 07:50 AM
A.R's Avatar
A.R
Anybody here running ACT Stage 2 - 6 puck with spring on their B18C???
GSR_97ek
Transmission & Drivetrain
Apr 10, 2014 05:12 PM
ej--1socal
15
Sep 3, 2008 05:10 PM
frknlo87
Jul 12, 2006 07:54 AM
gtofighter
May 26, 2006 07:20 AM
Hapa88
Jul 1, 2003 07:47 PM
