spoon rim/caliper ???
Old Sep 5, 2002 | 02:13 PM
purplehazek4's Avatar
Default spoon rim/caliper ???
i was wondering if anyone knew what offset and size regamster/sw388 rim will fit with the spoon caliper?i dont want to extend the studs or use spacers. thanks
Old Sep 5, 2002 | 02:16 PM
Reid's Avatar
Global Moderator
Default Re: spoon rim/caliper ??? (purplehazek4)
The 15x6.5" +45 Spoons need a 13mm spacer.
The 16x7" +45 Spoons clear the calipers without incident.
EDIT: Added offset.
[Modified by Reid, 1:17 PM 9/5/2002]
Old Sep 5, 2002 | 02:22 PM
Default Re: spoon rim/caliper ??? (Reid)
13mm?!will the rim even sit on the center hub?
Old Sep 5, 2002 | 02:26 PM
Reid's Avatar
Global Moderator
If you don't want to use spacers you have to get 16s in the front.
Old Sep 5, 2002 | 02:52 PM
migs's Avatar
PM Mario on this, he has done the mod under 15" spacers but I think he running into the clearance problems with his front fenders.
Old Sep 5, 2002 | 02:53 PM
Reid's Avatar
Global Moderator
Default Re: spoon rim/caliper ??? (Migs)
He's lowrider spec now.
Old Sep 6, 2002 | 12:08 AM
AJ PwR's Avatar
Spoon calipers with Spoon SW388 1565 +42 will require atleast 8mm spacer.
Old Sep 9, 2002 | 02:48 PM
99MR_SiR's Avatar
Default Re: spoon rim/caliper ??? (AJ PwR)
Question: Will the 16" Spoon SW388 Rims clear AEM's big brake kit. Anyone know? Thanks.
Old Sep 9, 2002 | 02:53 PM
Big Phat R's Avatar
Default Re: spoon rim/caliper ??? (99MR_SiR)
Blasphemy!
The AEM kit is not a worthy brake upgrade.
Old Sep 9, 2002 | 03:08 PM
99MR_SiR's Avatar
Default Re: spoon rim/caliper ??? (Big Phat R)
That's what I thought, but what would you suggest on a budget? I'm using OEM drilled Brembos now with Metal Master pads.... Nevertheless will it clear?
Old Sep 9, 2002 | 03:38 PM
yellow blur's Avatar
I will have detailed pictures and a writeup as soon as my calipers come in.
Old Sep 9, 2002 | 03:42 PM
bb6h22a's Avatar
Thats debatable; some say yeah it's ****, some say well, any time you increase the torque being applied to the rotor by moving the caliper outward, has a positive effect on brake feel. Personally, its the same w/ any big brake kit; what's hype and what truth depends on who you talk to, perosnally, I wouldn't use an AEM kit, or anything that involves moving a stock caliper further out w/ a bracket on a larger 'pretty' rotor, doesn't sit well w/ me, but to others thats just what the want.
Oh, and whoever was asking about fitment of the AEM kit; click below:
http://www.aempower.com/application/index.htm
[Modified by bb6h22a, 4:48 PM 9/9/2002]
WilC4
Suspension & Brakes
Dec 14, 2009 06:19 PM
WowOzYouRock
Honda S2000
17
Mar 12, 2005 05:48 PM
ABTDer
Mar 22, 2003 02:31 PM
Mario
Jul 2, 2002 12:58 AM
jeff652
Sep 20, 2001 01:23 PM
