45 offset spoon rims clear spoon calipers on an ITR?
will 45 offset spoon rims clear spoon calipers on an ITR? what is the correct offset if have spoon calipers? thanks
Re: 45 offset spoon rims clear spoon calipers on an ITR? (izan puos)
i think 18" spoon rims with a 45 offset might do it.
anyone else have an answer for me? thanks
Re: 45 offset spoon rims clear spoon calipers on an ITR? (Drunk-N-Munky)
I think Ben from A+J said only +38 offset will clear due to the spoke design of the Spoons
Re: 45 offset spoon rims clear spoon calipers on an ITR? (Big Phat R)
can anyone else clear this up for sure? someone with spoon calipers? thanks again
Global Moderator
The 16x7 +45mm offset will clear Spoon calipers.
Re: 45 offset spoon rims clear spoon calipers on an ITR? (Reid)
it "should fit" i would assume it would fit there own calipers... but non the less give ben a call at a&j
Global Moderator
Re: 45 offset spoon rims clear spoon calipers on an ITR? (azn98R)
16x7 +45mm Spoon wheels will fit an ITR with Spoon calipers.
There is no debate.
Yes, Reid is correct I have 16x7" spoon wheels on my ITR with spoon calipers and IT DEFINITELY FITs with no problems! If you'd like I can take pictures to prove it to you...(Props to spoon engineering, these things are a TIGHT fit if you do have the 45 offset wheels)...hope this helps!
[QUOTE]it "should fit" i would assume it would fit there own calipers... but non the less give ben a call at a&j[/QUOTE
since when did spoon make the sw388's?
Incorrect, Spoon designed the +38mm offset for the front of S2000s.
15" is a 6.5" wide wheel
16" will obviously clear the caliper since its wider and also since it has +45 offset
15" is a different story
Re: 45 offset spoon rims clear spoon calipers on an ITR? (MugenFG360)
Global Moderator
16" is a 7" wide wheel
That has nothing to do with fitment.
Founding Member
There is no debate.
There is no debate.
Why are you listing wheel widths?
go to any search engine and type in wheel offset, this will do wonders for you trust me! And like Reid says and MIKE M the combination that the original post creator asked about WORKS WITHOUT A DOUBT and there is NO DEBATE ON this!!
Global Moderator
the 7" wide wheel will accomodate more space inside than the 6.5" wide wheel?
Width has absolutely NOTHING to do with caliper clearance.
Width really wouldn't? Offset is measured from the center of the wheel so I assume two wheels which have the same offset but 1" more width on one of them would have a 1/2 inch more room from caliper to spoke.
