b20v problem 2nd...
Old Feb 1, 2010 | 12:00 PM
Mik2006's Avatar
Default b20v problem 2nd...
alright well my b20's actin up again after i just rebuilt the head after a bent valve issue. so this time now its idling rough just like when i bent a valve but dosent make any noise like it did before, plus the oil light is flashing on. but when its cold started i glows slowly then it starts to flash, and it spits out oil out the exhaust, or gas. and if i take off the oil cap there is a lot of air blowing threw. and runs very rough.
oh yah i do have a oil pres gauge and its around 50 but it may go up like 5 or 10 or down 6 or something with the idle.
Old Feb 1, 2010 | 05:29 PM
hey man's Avatar
Default Re: b20v problem 2nd...
um usually that oil spitting out of your exhaust has to do with pistons rings after reving up to a certain amount of RPMs it shoots out oil . but the rought idle idk what that could be to tell u the truth .....
Old Feb 1, 2010 | 06:39 PM
b20vtek's Avatar
blowby usually means piston rings, oil out of the exhaust also means piston rings
Old Feb 1, 2010 | 06:50 PM
95skunkedgsr's Avatar
do a leak down and compression test and go from there
Old Feb 1, 2010 | 07:19 PM
Mik2006's Avatar
ugh i was afriad of that. cause its spitting oil at even 1k rpm. most likely is the piston rings are gone, but i duno about the rough idle
Old Feb 1, 2010 | 07:22 PM
00Red_SiR's Avatar
All Motor Mentor
sounds like a hole in a piston.
Old Feb 2, 2010 | 10:27 AM
Mik2006's Avatar
anyone think it could be bad gas? how would i check for that.
Old Feb 2, 2010 | 01:08 PM
negusjuda's Avatar
bad gas no sounds like piston rings or valve seals seems like your getting blow by and the ruff idle could be oil on the plugs might need a rebuild
Old Feb 2, 2010 | 03:50 PM
Mik2006's Avatar
^^^ yah thats what im thinking now... ugh not agian.
jdawg916
Apr 10, 2011 03:37 AM
Hharrishonda
Jun 14, 2008 05:59 AM
kihun_cha
Jan 2, 2006 07:45 AM
IloveNewt
Dec 21, 2003 10:18 AM
Islander
May 22, 2003 03:20 PM
