REAL QUIK: Engine Question... HELP!
Old Sep 5, 2002 | 01:46 PM
skunk2unerz's Avatar
Default REAL QUIK: Engine Question... HELP!
i found a 93 LS motor at the junkyard... ITs an AUTO...so will the blok still work if i used manual TRANNY? or what would i have to do....please hurry B4 its gone.
thanks.
-P.
Old Sep 5, 2002 | 01:56 PM
KTeller8's Avatar
Default Re: REAL QUIK: Engine Question... HELP! (skunk2unerz)
not to sure on b series but a block is a block.. shouldnt matter
its the ecu and tranny that matters
Old Sep 5, 2002 | 02:15 PM
HXMan's Avatar
Yes.
Old Sep 5, 2002 | 05:00 PM
Default Re: REAL QUIK: Engine Question... HELP! (HXMan)
Okay maybe i need to clarify what I wrote:
I just came from a junkyard that has a AUTOmatic LS. I was wondering if got the block from that TEG, would a manual tranny(any B-series) slap on to it without a problem. If it is not too much trouble, I might just go there and get it.
Oh and do you think its worth $150 for the whole block and parts of the head (someone already scavenaged parts of it). Its a 93 w/ lik 195K.
Would it be worth it to rebuild?
Old Sep 5, 2002 | 09:56 PM
salbaje's Avatar
yes you can rebuild it. yes the manual tranny will bolt up you just need to get the clutch parts for it. flywheel, clutch disc and clutch pressure plate. also if you do change it to manual use the mt bolts for flywheel as the at bolts are shorter
LimpSalamander
Jan 9, 2019 12:24 PM
skateboard_ej8
Aug 23, 2007 07:47 AM
MetalHead4454
Sep 12, 2005 01:38 AM
skunk2unerz
Sep 5, 2002 04:57 PM
dingusjt
Jun 13, 2002 07:46 AM
