View Poll Results: how can i fix this
should i fix it?
100.00%
turn this into a derby car and blow the motor?
0%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
Please help! leaking oil and idle problem
Old Jan 31, 2010 | 08:00 PM
OMGdjdy's Avatar
Default Please help! leaking oil and idle problem
i have a 95 integra SE with a b18b motor, there's a oil leak coming from the Circle plastic on the head next to the distributor its a small leak though, is there anyway i can stop the leak like seal it with something? or does that leak mean something?
there's a picture of where its coming from.....
here my other problem when i first got this car the car was idling at 4500rpm at start and begins to progress downwards as the motor gets warm to like 3000rpm to 3500 rpm, well i was reading some forums and found out that Integra has this problem, well first off they told me to clean the FITV aka Fast Idle Thermo Valve and Throttle and i clean it as good as i can and that drop the RPM down to 1900 to 2000rpm, well even though the car is warm up the rpm still stays the same, well then i tried cleaning the IAC as good as i can and that didn't do a damn thing!!, i haven't tried cleaning the manifold yet but i don't think it would have made a differences, i think it something else because i have the the throttle complete screw shut and its still sitting at 1900rpm and 2000rpm wtf? at this point I'm totally confused to what to do next i need your help to finding this problem can it be a sensor? since i just got this car i havent tried putting in new sensors
Old Jan 31, 2010 | 08:27 PM
mouab18c1's Avatar
Default Re: Please help! leaking oil and idle problem
the black plug is your cam plug. just buy a new one from honda and replace it
Old Feb 1, 2010 | 11:07 AM
OMGdjdy's Avatar
ahh thanks anything, do you know the problem to my idling problem at all?
Old Feb 1, 2010 | 10:12 PM
RichSC's Avatar
Not sure on the idle problem, but get a billet cam seal/plug from Blox, Skunk2 etc, valve cover gasket and some Hondabond. The OEM plug will break down and start leaking again eventually.
Old Feb 2, 2010 | 06:23 PM
OMGdjdy's Avatar
thanks rich gave me a good answer
Old Feb 2, 2010 | 08:01 PM
b20vtec turbo's Avatar
go to lightening motorsports or call them at 225-752-2738 and they can ship you one i think there like 40 bucks or so
Old Feb 2, 2010 | 08:07 PM
its not the oem one so it wont leak i bought one bout three years ago and it still hasn t leak
Old Feb 2, 2010 | 08:08 PM
also is the check engine light on
christin
Jan 12, 2007 04:36 AM
nevin
Dec 12, 2004 11:52 AM
Takashi1978
Nov 27, 2004 06:42 AM
krazn
Oct 5, 2002 09:16 PM
