B18C build questions
Old Jan 31, 2010 | 09:26 AM
DC2_R's Avatar
Default B18C build questions
Right now I am leaning towards building a "poorman's ITR" for my EK. I am looking at using a B18C block/crank with a B16A/B18C5 head, B16B pistons and LS rods. The compression would be just below 11.5:1. Forgot to mention I am going NA on this build.
My area of concern is the rods. Does any have objections to the rods and if so why?
Scott
Old Jan 31, 2010 | 09:36 AM
ltrkstr2k's Avatar
Default Re: B18C build questions
just leave the gsr rods. are you gonna boost it or run NA
Old Jan 31, 2010 | 10:43 AM
DC2_R's Avatar
Updated original post, regarding going NA.
Old Jan 31, 2010 | 11:12 AM
mar778c's Avatar
Community Builder
Community Influencer
OP, you can not use ls rods and gsr crank. CTR pistons will yield much higher CR than 11.5:1 with a gsr or ls crank.
Old Jan 31, 2010 | 11:52 AM
DC2_R's Avatar
Ah okay. Thank you for the insight regarding that. What would you recommend, B16A2 with B16B or B18C with USDM ITR pistons?
Scott
Old Jan 31, 2010 | 12:09 PM
Thomascivicsi's Avatar
P30 are the best way to go if you ask me and wont have to worry about any piging....
Just throwing it out there
Old Jan 31, 2010 | 12:10 PM
mar778c's Avatar
Community Builder
RS machine pistons, ITR style.
Old Jan 31, 2010 | 12:35 PM
DC2_R's Avatar
Well the site I checked regarding compression ratios the P30 and the P73-00 there is not much difference of .05 between the two. So I think I am going to run the P73-00 in this build.
Now what about the head? I am going to be running a B16 head. Would the stock dual ITR valve springs be good enough for 8000 rpm or would you recommend something else do to the added comfort? What are good cams? I am thinking Toda, Bloc or OEM CTR/ITR.
Scott
Old Jan 31, 2010 | 01:50 PM
ltrkstr2k's Avatar
here is my old build its kinda in the same and was very decent for a na setup.
gsr block
gsr rods
gsr crank
p30 pistons
b16 head
blox springs
ITR cams
blox IM
blox 68mm tb
aem rail
rc 310s
chipped p28
Old Jan 31, 2010 | 02:06 PM
DC2_R's Avatar
gsr block
gsr rods
gsr crank
p30 pistons
b16 head
blox springs
ITR cams
blox IM
blox 68mm tb
aem rail
rc 310s
chipped p28
Do you have dyno sheets for this setup?
Old Jan 31, 2010 | 02:26 PM
ltrkstr2k's Avatar
na never got a chance to get it dyno'd. im actually rebuilding it gonna go with a new head setup.
beyondstock
Mar 8, 2009 12:41 AM
GOLDBERG
12
Jun 10, 2003 09:13 AM
BlwnBlue
Jul 12, 2002 12:51 PM
tinkerbell
Jan 7, 2002 08:56 AM
