obd2a ls/vtec question
Old Jan 31, 2010 | 04:34 AM
allmotorb18c14door's Avatar
Default obd2a ls/vtec question
im bout to do an ls vtec in my 97 hatch, and i was recently told if its not running an obd2a ecu when i take it to maryland emission it will fail, so i was wondering if there is any other routes to go, as in using a obd2 gsr or si ecu or another, or could i just use the obd till i take to emission and just switch back to the obd2 just so it will pass, i mean they dont start car since its obd2 they just scan to see if the cels are on or not. please lmk thnx
Old Jan 31, 2010 | 06:28 AM
DVDr's Avatar
Default Re: obd2a ls/vtec question
The best Way is to do it as you said.
Tune your car on OBD1 , and when you go for emissions install a usdm obd2a Vtec ecu. GSR, type R .
You will have to have a crank angle sensor for the obd2a ecu not to throw a code. so Remember that when doing your motor build .
Old Jan 31, 2010 | 02:31 PM
yeah i know that its a obd2 ls, witha gsr head, my buddy said to run a obd2a non vtec ecu when i take to emission cause the vtec one will have knock sensor in it and itlls throw code for it
j13
Engine Management and Tuning
Oct 5, 2013 10:10 PM
lukehowell88
Nov 11, 2007 01:39 PM
crispchris
Jun 28, 2007 09:00 AM
hamburgler
Feb 8, 2006 01:28 PM
pushinlsteg
Jan 6, 2006 07:11 PM
