Suspension & Brakes Theory, alignment, spring rates....
Brake Disc Screw Stuck -- 94 Civic coupe
Old Jan 30, 2010 | 05:52 AM
Scooby9's Avatar
Icon6 Brake Disc Screw Stuck -- 94 Civic coupe
Hi everyone,
I'm working on my 94 civic and can't get the front discs off. The two screws that hold the disc in place are seized and won't come off. I have tried WD-40, an impact wrench (not the power tool) and even a blow torch to heat the screw.
I'm willing to buy a tool if it will get the job done. The discs need to be replaced, they have grooves.
Click here if no image below:
Old Jan 30, 2010 | 06:08 AM
phunhaus's Avatar
Default Re: Brake Disc Screw Stuck -- 94 Civic coupe
Find a drill bit the size of the head and drill until you meet the rotor. Once the rotor is off, you'll be able to easily get pliers on the remnants of the screw stud and back it out.
Old Jan 30, 2010 | 06:21 AM
Scooby9's Avatar
I'll give it a try and let you know how it went.
Old Jan 30, 2010 | 09:22 AM
Scooby9's Avatar
Icon2 Re: Brake Disc Screw Stuck -- 94 Civic coupe
it worked, thanks.
I'm driving around with my new disc. I did drill too far and couldn't get the screw out, but the disc went right over it. The bolts should keep everything on right?
Old Jan 30, 2010 | 03:32 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
you really don't need the screws, they just keep the rotors in place when you take the wheels off.
an easy way to take off the screws were to get a screwdriver with a nice point, and hammer the screw off
Old Jan 31, 2010 | 02:12 PM
EFRue57's Avatar
or get an impact screw driver. any time i've had problems with those screws, the impact screw driver has done the trick.
b20acura
26
Aug 29, 2011 08:03 PM
CrX-WoRlD
Feb 18, 2007 01:55 AM
B16EJ
Jan 23, 2005 02:23 PM
377Z
Sep 3, 2004 02:33 PM
Boostage
Apr 25, 2004 06:41 AM
