to vtec or not?
Old Jan 29, 2010 | 09:31 PM
efjones9's Avatar
Default to vtec or not?
So I want to build a high compression single cam, but don't know which route to take. If I go non vtec ill be running a zc head with a cam re grind from bisimoto. With a d16a6 block. 2nd option will be a d16a6 block with p29's and z6 head. With obd1 conversion. I want to see what the positives and negatives will be with these set ups. Just want an opinion thanx
Old Jan 29, 2010 | 09:33 PM
BiG ChOr!Zo's Avatar
Default Re: to vtec or not?
second option is a first class ticket to the ref station
Old Jan 29, 2010 | 10:00 PM
prelude182's Avatar
ill be doing something similar to your second option. y7 block, y8 block, p29 pistons so on and so on. If i remember correctly the p29 pistons and rods will make around 11.5:1 or more cr on my setup. i think it will be less on the z6 head but dont take my word for it, research it bro.
Old Jan 30, 2010 | 01:00 AM
efjones9's Avatar
Exactly why I'm skeptical about the z6. I just want more power! Lol. I want power but don't want it to be a hassle
Old Jan 30, 2010 | 09:57 AM
freydaddy's Avatar
thats what setup i have. boosts the compression about 1 point.
very reliable. *** dyno'ed about 145 hp.
Old Jan 30, 2010 | 01:29 PM
efjones9's Avatar
What octane u runnin? How's mpg?
Old Jan 30, 2010 | 02:45 PM
blasterman87's Avatar
i have a feeling the *** dyno and the real dyno will be totally diffrent on that... i would go the first option if its good for emissions in your area... motors no good if you cant run it
Old Jan 30, 2010 | 03:26 PM
crx_si-r's Avatar
He should be ok as long as you run a valve cover that doesn't say "vtec" you will do fine. I don't see why you would be sent to ref, unless your showboating.
Old Jan 30, 2010 | 07:03 PM
efjones9's Avatar
Anyone know a reliable compression calculator site? Can't find a good one
Old Jan 31, 2010 | 04:13 AM
Sikocivic's Avatar
Here you go;
http://www.c-speedracing.com/howto/c...c/compcalc.php
Old Jan 31, 2010 | 01:21 PM
freon480crx90's Avatar
im runnin A6 block milled .015 to almost zero deck my P29s with a ported Z6head with a bisimoto stage three cam. not passing emissions anywhere. but making more power than most straight swaps out there.
Old Jan 31, 2010 | 02:53 PM
what do you mean by most straght swaps out there? what numbers you putting down?
Stingray96
Jul 11, 2006 11:20 AM
tobe1424
Feb 22, 2006 08:24 AM
NirVTEC
Oct 18, 2005 12:12 PM
mrmechanic
Oct 15, 2004 05:16 PM
SohcVtecCrix
Sep 21, 2002 06:32 PM
