GSR Taking 15+ cranks to start
Old Jan 29, 2010 | 03:15 PM
AlexDphoto's Avatar
Default GSR Taking 15+ cranks to start
Hi all, ive searched everywhere and have threads up on different forums, but i wanted to see what you guys thought about my situation over here.
My car lately, actually since december, is taking about 15+ cranks to start, or itll just go until the battery dies and i need a jump. ive done nothing to the motor since i purchased a year ago. its currently at a tuners shop getting looked at but theyre stumped too. heres a list of mods
this issue is only a pain in the *** when the car is completely cold, like i sleep at night wake up in the morning and need to go to school and it doesnt start.
the longer i leave it the more problems it has starting.
Last week we had 30 degree weather and the car had no problems starting after 3 tries, but now the temps dipped back to single digits and the car sat outside for 4hrs and didnt start till i hooked it up to jumper cables and kept going because i literally would have to keep trying to start it till the battery died.
so temperature is the only major affecting variable i can see.
2000 Acura Integra GSR
b18c1
aem cai
skunk 2 intake manifold
70mm tb port matched with IM
port polished head
skunk 2 valves
ferrea retainers and springs
skunk 2 cam gears
dc sports header
jdm type r pistons
narrow band
oil pressure gauge
b&m fpr
fuel pressure gauge
tuned on crome
Compression is 230 across the board and the fuel pressure is there when the car starts. The car IS getting spark and fuel as i was told by my tuner.
Here is a list of items that have been tested on the car/replaced
walbro 255lph pump
fuel filter
msd distributor
ngk spark plugs
new ecu
jumper harness
fuel injectors
rewired fuel injectors
battery
starter switch
Im stumped at the moment on what it could be. ive searched my topic already and havent come up with anything i havent tried yet so if someone could throw me some ideas on what could possibly be going wrong, please do!
thank you!
Old Jan 29, 2010 | 03:36 PM
dothacker's Avatar
Default Re: GSR Taking 15+ cranks to start
have you guys checked the starter? what are the troubleshooting steps you've performed thus far? try tapping the starter with a hammer and then try starting it.
Old Jan 29, 2010 | 03:39 PM
AlexDphoto's Avatar
ill bring that up with my tuner tomorrow i forgot whether or not he checked that.
Old Jan 29, 2010 | 03:57 PM
rankin_wanavtec's Avatar
check plugs / advance your ignition timing
Old Jan 29, 2010 | 04:04 PM
AlexDphoto's Avatar
plugs have already been checked, gapped, and replaced. thanks though.
Old Jan 29, 2010 | 04:17 PM
AlexDphoto's Avatar
i added more to the first post
Old Jan 29, 2010 | 05:19 PM
dothacker's Avatar
:D sometimes the simplest things get taken for granted... i speak through experience lol
mouab18c1's Avatar
sounds like my brothers car. push start always work
Old Jan 29, 2010 | 06:13 PM
jimmy o.'s Avatar
hows your fuel pressure?
nvm just read you have a 255 lol
Old Jan 29, 2010 | 06:20 PM
AlexDphoto's Avatar
fuel pressure when the car is primed is at about 40psi if i remember correctly. running it was about 55psi.
AlexDphoto's Avatar
id imagine something like that would be the first thing that is checked.
i forgot completely what he went over.
im going to have him double check the ignition fuel tables tomorrow too.
Old Jan 29, 2010 | 06:21 PM
AlexDphoto's Avatar
haha i wish i had the muscle to do something like that.
on the other hand the car in you avy looks just like mine.
Old Jan 31, 2010 | 07:29 AM
AlexDphoto's Avatar
Update 1/31
Went to the shop and spoke with the tuner, hes stumped but is determined to figure out this problem. He says its really intermittent, and that the cause may be a bad ground in the system. Hes checked out the grounds in the engine bay only to find that they are indeed okay, however theres one more inside the car he wants to look at.
I had an alarm guy stop by the shop to take a look at the car to install a compustar and he says that the underside of the dash looks like spaghetti and that the previous alarm and gauges were installed very amateurish.
on another note, we are also going to try a new coolant temp sensor to see if it changes anything and hes going to datalog the car while its having problems to see if the computer can catch anything.
the fuel cranking compensation table has been checked and is fine btw
Old Jan 31, 2010 | 07:35 AM
Did you advance your ignition timing? unless its too advanced, might need to be retarded.. Check that, I had the same issue with my car. i advanced my ignition timing a bit. flawless starts and Im in -15 degrees celsius weather right now. If as you say you checked everything else, i can almost guarantee that your ignition timing is either too far in advance or retarded.
Old Jan 31, 2010 | 07:54 AM
oh, srry, didnt read your whole response, then i am also stumped.
Old Jan 31, 2010 | 08:43 AM
Dogginator's Avatar
Daisy... Daisy...
Is it possible that you got bad gas? I am having a similar issue when the car is cold (below 20 F). I just filled again on Thursday and the problem seems less.
Old Feb 1, 2010 | 12:06 PM
AlexDphoto's Avatar
unless 20+ tanks of gas were bad i dont think so
Old Feb 1, 2010 | 12:07 PM
AlexDphoto's Avatar
threw a new map sensor on with no change btw. going to try new coolant temp sensor
lawlss
15
Sep 14, 2009 10:23 PM
nighttrain33
10
Feb 25, 2007 08:10 PM
gaydm.accord
Mar 30, 2005 06:20 PM
Jet Black
Sep 10, 2003 07:07 PM
