90 DA b18 turbo BUILD
Old Jan 29, 2010 | 02:03 PM
khellapeter's Avatar
Default 90 DA b18 turbo BUILD
I got a stock 90 DA
and i just picked up a stock b18 head
My plan is to rebuilt the head so that it would be perfect for turbo. If i could get some pointers and opinions on where to start that would be very much appreciated.
Here are some questions that i have also
Q: If i get new valves for the head what kind/size should i get and does that mean i have to change my springs and rockers?
Q: Do i have to change my cams and cam gears?
Q: When i go get the head machined what measurements should i ask for?
Old Jan 29, 2010 | 02:25 PM
Default Re: 90 DA b18 turbo BUILD
BUMB-BEDIE-BUMB
Old Jan 29, 2010 | 02:55 PM
sleekcesar's Avatar
some set up im a end up goin with bro! keep us updated
Old Jan 30, 2010 | 09:23 AM
yo i will! im going to remove the stock valves today
Old Jan 30, 2010 | 09:51 AM
20-EM2-05's Avatar
GL on the build. You should check the F/I section, they have a whole bunch of useful builds + set ups.
https://honda-tech.com/forums/forced-induction-16/lst-ls-t-turbo-b18a-b18b-setups-1323059/
Such as that one.
What are your turbo plans? and your WHP goal?
Old Jan 30, 2010 | 10:19 AM
thanks
Old Jan 30, 2010 | 11:28 AM
josh-roy's Avatar
why wouldn't you build the bottom end?
Old Jan 30, 2010 | 11:34 AM
Hatorade's Avatar
I got a full crower head, 62404 cams, dual valve springs, retainers, crower valves. pm me if interested!
Old Jan 30, 2010 | 02:34 PM
VerySlowDA9's Avatar
My friend did a boosted LS and made 420 Hp
Old Jan 31, 2010 | 11:02 PM
tepasoelrolo's Avatar
i have a boosted 92 da and i am pushing 432 horsepower and 355 torque on 18 psi b20b no block work just get a great tune and thats it and also get garrett turbo good luck
Old Jan 31, 2010 | 11:12 PM
hookedonponics's Avatar
http://www.beesandgoats.com/boostfaq/g2icturbo.html
gen 2 turbo guide
Old Feb 1, 2010 | 05:24 PM
thanks for all the heads up guys! naw i want the experience of building the head. and that beesandgoats site have some useful tips.. well im gonna get my head hot tanked this week then time for measuring and machining... anyone know what i should go with?? and i was considering building the bottom half just a bit skeptical with it
Old Feb 1, 2010 | 06:53 PM
yellowBANDIT's Avatar
i got some crower stage 3 turbo cams if you like. For the bottom sleeve the block or get it sleeved i should say.
Old Feb 1, 2010 | 07:15 PM
Bond's Avatar
If the bottom end has alot of km's on it, I personally would recommend rebuilding it aswell. not to say it wouldn't work, but if the rings are worn and your burning oil, it will only get worse when boosted.
Old Feb 2, 2010 | 08:39 PM
how much for the turbo cams yellowBANDIT
Old Feb 2, 2010 | 08:40 PM
and i believe that my motor has 255k original miles but i got it at 235K and been pretty healthy.. just oil pan leaks
civic_90_sata
Jan 24, 2015 04:25 PM
Big Rhag
May 17, 2013 01:20 PM
93b20z
Feb 3, 2011 04:12 AM
typocdf22
Feb 16, 2009 03:24 PM
dc2monkie
Sep 24, 2003 04:31 PM
