aem CAI
Old Sep 5, 2002 | 11:04 AM
boonacka's Avatar
Default aem CAI
when installing an aem cai, two vacuum hoses are removed. one from the FIA (Fuel Injection Air) valve and the other from the IAR (intake Air Resonator). what would happen in i capped those vacuum hoses?
Old Sep 5, 2002 | 11:06 AM
Gennady's Avatar
New User
Default Re: aem CAI (boonacka)
Nother. One is for crankcase venting, the other is for idle vacuum.
Old Sep 5, 2002 | 11:09 AM
boonacka's Avatar
Default Re: aem CAI (Wont be beat)
so its ok to cap those vacuum lines?
Old Sep 5, 2002 | 11:11 AM
Gennady's Avatar
New User
As long as you put on crankcase breather filter where the crankcase tubes came from.
Old Sep 5, 2002 | 01:03 PM
niedejb's Avatar
The two vacuum lines need to be capped. The CAI should have a place to connect it to the valve cover.
Old Sep 5, 2002 | 03:24 PM
tornactive.com's Avatar
Sort of..
it does affect the vaccum pressure that your car uses to idle and run correctly. it blows hot air back into the intake (it does) but it is so minimal that it has no effect on performance and sometimes better to just keep that part hooked up
This is just my opionion and from on hands experience, but you can do what you like.
[Modified by tornactive.com, 12:26 AM 9/6/2002]
busyychild
Aug 21, 2006 05:29 AM
idriveanimport
Dec 13, 2003 04:20 PM
raver69
May 22, 2003 12:16 PM
hobo79
Jan 28, 2002 05:12 PM
