need some help for a lsv swap
Old Jan 28, 2010 | 11:22 PM
jmabo205's Avatar
Default need some help for a lsv swap
I have a 91 DA with a b16 head and i'm having problems getting my vtec to kick in. I checked the wiring from the ecu(pr3) to the vtec solenoid... thats good, i checked the oil line and thats good too. So the only thing is the actual solenoid its self right? Does anyone one know how to check if its still working? Also does the map sensor have anything to do with it?
Old Jan 29, 2010 | 10:15 AM
ls_vtec_da's Avatar
Default Re: need some help for a lsv swap
it can be possible for the vtec solenoid to be bad i just dont know how to check it my brother had a problem with his lsv the vtec solenoid keep turning on and off in vtec turned out to be the wire he ran was going bad.
Old Jan 29, 2010 | 10:35 AM
zedron's Avatar
You can check it by taking the one wire from it and applying 12v to it. If it clicks then its working correctly. Make sure to disconnect the solenoid from the harness first before doing so.
h22killer
Engine Management and Tuning
Oct 1, 2011 04:57 PM
josh's ep3
Dec 8, 2008 05:59 PM
its WANG yoO
Apr 28, 2004 12:34 AM
hioutput
Jan 7, 2003 12:39 PM
oneslowHB
Apr 24, 2002 02:44 AM
