Called up ground control today.
Old Sep 5, 2002 | 10:10 AM
Gennady's Avatar
New User
Default Called up ground control today.
Call 1:
Riiiiiing
"Ground Control"
"Yes, Hello, I have a question about your coilovers..."
CLICK (sound of phone hanging up)
Call 2:
Riiiiiing
"Ground Control"
"Hello, I have a question..."
Some customer service!!
Anyway, so I will ask here. I bought a used set of GC coilovers and they came with these black rubber cylinder thingamagigs with a slit down the side. What are those for? Here is a picture...they are red at the bottom right in this picture.
Old Sep 5, 2002 | 10:27 AM
Slurp56's Avatar
Default Re: Called up ground control today. (Wont be beat)
They slide between the sleeve and the strut to keep it from moving/rattling. Use the rubber O-rings as spacers betweent the urethane and the strut so everything is tight and doesnt move.
Old Sep 5, 2002 | 10:38 AM
n1ek's Avatar
what kind of car are those going on?
the springs look all wrong for most honda/acura apps.
Old Sep 5, 2002 | 10:43 AM
Gennady's Avatar
New User
Default Re: Called up ground control today. (Slurp56)
I dont have the rubber rings. Are they essential?
That is just a picture of GC knock-off. I have the real GC's with progressive springs. They are going on a 4th gen Accord (see sig).
Old Sep 5, 2002 | 10:48 AM
VTECorona's Avatar
If your sleeve fits snug around the shock then I would just put a thin layer of electrical tape so give some type of sheathing so its not metal on metal. I couldn't fit the rings around my fronts so I just coiled electrical tape around on the top and bottom side until the sleeve fit snug onto the shock.
Old Sep 5, 2002 | 10:55 AM
n1ek's Avatar
i htough all the ground controls came with linear springs???
Old Sep 5, 2002 | 11:14 AM
Gennady's Avatar
New User
Default Re: Called up ground control today. (97RedTegGSR)
Thanks for the tip.
Gennady's Avatar
New User
Default Re: Called up ground control today. (n1ek)
Thats what Corey said too, but mine are indeed Eibach and indeed progressive rate.
Old Sep 5, 2002 | 12:01 PM
keithv's Avatar
nope, you can get linear or progressive springs from ground control.
Old Sep 5, 2002 | 12:10 PM
Lamchop0000's Avatar
WTF those arent ground controls those are the ebay wannabe's that i got! but all my springs were even hieght not longer then the other 2
edit: i have the instructions for the installtion if you want them ill send it to you its like 1 piece of paper with pictures on how to modifiy the shock sleeves to work with that upper piece your having problems with.
[Modified by lamchop0000, 1:14 PM 9/5/2002]
Old Sep 5, 2002 | 01:37 PM
Gennady's Avatar
New User
Default Re: Called up ground control today. (lamchop0000)
Thanks, please send to amhummer12@hotmail.com
Old Sep 5, 2002 | 01:45 PM
KTeller8's Avatar
he knows that ..read the post of his up top.. he used it as a reference and picture
Old Sep 5, 2002 | 11:48 PM
Default Re: Called up ground control today. (KTeller8)
DOH damn i looks like an ***
about that thing i said ill send, its a piece of paper its not a email.
Old Sep 6, 2002 | 12:37 AM
SoulSurfer's Avatar
This is the first I've heard of poor customer service at GC. Usually they're eager to answer my questions.
Old Sep 6, 2002 | 06:25 AM
Gennady's Avatar
New User
Can you scan it?
Gennady's Avatar
New User
Default Re: Called up ground control today. (LSDelSol)
Fokurs!
Old Sep 6, 2002 | 07:11 AM
96 SOHC VTEC's Avatar
That is what I was going to say. When I called I had excellent customer service.
Old Sep 6, 2002 | 07:26 AM
Gennady's Avatar
New User
Default Re: Called up ground control today. (96 SOHC VTEC)
He was probebly PMSing, because even the "Ground Control" was very uninterested and rude.
Old Sep 6, 2002 | 01:20 PM
Muckman's Avatar
Moderator in Chief
Ive had some experience with Ground Control's customer service. They are helpful if you ask the right questions but they are very curt with you. They are also very protective of their specs, which is understandable considering the competition. Great product, service could be better. But I have certainly seen worse.
I had a 20 min conversation with one of their guys about installation and he really knew his stuff and helped me figure out why my springs were rubbing on the sleeves.
They told me custom spring rate springs were linear rates where the stock spring rate springs were semi progresive.
[Modified by Muckman, 5:22 PM 9/6/2002]
Old Sep 6, 2002 | 02:24 PM
vactor's Avatar
Default Re: Called up ground control today. (Muckman)
i called them to ask tech questions, they wouldn't even tell me the spring rates on the coilovers for civics until i purchased them. they were real F_ucking D_icks!!!
Old Sep 6, 2002 | 02:25 PM
VTECorona's Avatar
Muckman, what did he say about the spring rubbing the sleeve? Mine used to do that once I installed them it made like a nasty scratchy sound whenever I hit bumps of a certain size and I couldn't figure out why. I retorqued each bolt and it went away.
Old Sep 6, 2002 | 03:14 PM
Muckman's Avatar
Moderator in Chief
Yeah they dont want to tell you the spring rates until you are ready to buy them. They're dicks like that. But they are 350F/280R (maybe its 380F/250R cant remember) but its something like that on the Integra kit. I got custom rates anyways
<U>Sleeve Rubbing</U>
My springs were rubbing on the top 2" of my Ground Control sleeve each time the spring would compress. Effectively rubbing away one side of the threading.
Solutions:
1.) Make sure your using the Koni adapter ring (as I was using Konis). It will wobble without it.
2.) The front sleeves are supposed to be the 4" sleeves and the rears are suposed to be 6" but I had them on backwards because they shipped them paired up with the incorrect springs. The 8" front springs were paired with the 6" rear sleeves. And Visa versa. So I installed them that way
-So even tho the top of the sleeve was flush with the top of the shock - the spring would compress and it would arc very slightly and you could watch the spring get closer to the sleeve as weight compressed it slowly until it actually touched the sleeve If the proper, shorter sleeves were used up front there would'nt have been sleeve near the top 2" where the spring was rubbing on it. Problem Solved
3.) He also said you can move the Koni adapter and perch, down a notch on the shock so that the entire unit is lower and then move the adjuster up an equal amount to achive the same ride height - hense having the same effect as above.
Sorry I dont have my pics developed yet or I would post them. Damn I feel like a Ground Control pro now! Conclusion: I ended up just buying new 6" sleeves ($15ea) after I fixed the rubbing problem.
Old Sep 6, 2002 | 04:02 PM
mackymcg's Avatar
Jeebus! I had mine on fro about a month now and I didn't know I put the sleeves backwards!
What length springs are you using, and how is your ride height, are you lowered significantly, like more than 1.25 or so?
I have the 6" sleeve on the front, but I'm using 8" springs and am going to go just .25 lower than stock, right now I'm .5 over stock(thought I'd let the springs settle). I'm hoping I won't rub.
Did anyone here buy the perch wrench from them? Is it expensive, i've heard some high prices when asking about this, though I haven't called GC yet.
As for ground control's customer service, I had no problem with them when ordering my stuff, but the shipment was horrible. I also ordered a set of ST swaybars and they shoved everything I ordered (2 Konis, GC kit and springs, ST swaybars) all in the box for the swaybars, everything was just sliding around and the box was bulging at the sides.
Old Sep 6, 2002 | 11:10 PM
Muckman's Avatar
Moderator in Chief
Default Re: Called up ground control today. (mackymcg)
Front: 8" 400lbs/in
Rear: 7" 400lbs/in
Yes Im lowered alot. Im not sure how much Im lowered (everyone asks, but its so hard to tell with Ground Controls). Im not slammed but tonight its about a 1 finger gap front and rear. Camber is my friend I had this problem when I originally installed the suspension and wasnt lowered much.
Infinity_Racer
Suspension & Brakes
Feb 15, 2008 11:46 PM
chethewitt
Nov 24, 2002 11:00 PM
Edwin
Mar 18, 2002 10:36 AM
Brewer
Feb 7, 2002 07:37 PM
