Transmission & Drivetrain Gearboxes, Differentials, Clutches
Ever put a hydro gsr ring gear in a hydro ls?
Old Jan 28, 2010 | 09:35 AM
scspeed's Avatar
Default Ever put a hydro gsr ring gear in a hydro ls?
Was thinking about doing this becouse its the only ring gear i have around...anyone ever do this? do they like it? any major difference?
Old Jan 28, 2010 | 09:41 AM
Aquafina's Avatar
Default Re: Ever put a hydro gsr ring gear in a hydro ls?
Yes. You have to use the matching countershaft and GSR diff.
Old Jan 31, 2010 | 05:35 PM
scspeed's Avatar
a gsr dif? that wont fit in an ls case would it? i thought b16 and ls were the same but gsr dif was different
Old Feb 1, 2010 | 07:16 AM
highmilehatch's Avatar
You cannot bolt the GSR ring gear to LS diff. It will also interfere with countershaft, hence needing the gsr countershaft. You can, however put complete GSR ring gear, diff, counter and main shafts INTO LS hydro case. Not sure if that's what you meant.
Old Feb 1, 2010 | 07:56 AM
Aquafina's Avatar
GSR diff is different, that's why you have to use it if you want to use the GSR FD. GSR diff fits in the case. Easiest way to get the 4.40 FD would be to just use a B16A2 FD.
Old Feb 2, 2010 | 09:19 PM
building boost's Avatar
ill trade you an ls ring gear for your gsr ring gear...
88 yellow crx
Feb 25, 2007 06:38 PM
Lscivichatch92
14
Oct 11, 2004 04:25 PM
Toda Party
Sep 18, 2003 02:59 PM
Burke
Jun 3, 2003 02:32 PM
