upper radiator hose route
Old Jan 28, 2010 | 09:06 AM
motrayEG6's Avatar
Default upper radiator hose route
i want to make sure my upper hose is connected where it is suppose to be i have a 92 civic hatch with a b18c swap and right now my upper is goin into the front dizzy side of the head
Old Jan 28, 2010 | 09:33 AM
killahatch's Avatar
Default Re: upper radiator hose route
when you say front do you mean to the side of the dizzy below the vtec solenoid? i have a b20 swap in my ek and im using gsr hoses and other end of the hose goes right below the cam plug which on the gsr motor the vtec solenoid is there(so is the cam plug but its in front of the solenoid)
hope this helps.
Old Jan 28, 2010 | 11:19 AM
dpetro1's Avatar
mad ms paint skills
can you tell im bored at work?
Old Jan 28, 2010 | 11:23 AM
Schister66's Avatar
Man U FTW
Yep...lower to the thermostat. That's the way to remember...it lets the cool coolant in which 'pushes' the hot coolant out
Old Jan 28, 2010 | 01:25 PM
motrayEG6's Avatar
thats where i have it but my fan is not turning on so i just thought i had it in the wrong spot cause i checked all the electrical stuff for my fan and it works but never turns on, and my motor never overheats
Old Jan 28, 2010 | 01:46 PM
dpetro1's Avatar
it takes quite some time for the fan to come on especially at idle. im sure you are fine. if you stat overheating while in traffic then look into why the fan isnt coming on. also make sure the coolant is bled properly that can cause the fan not to kick on too
Old Jan 28, 2010 | 02:48 PM
motrayEG6's Avatar
i will check into bleeding my coolant thanks man
Gradin91hatch
16
Dec 27, 2011 05:15 PM
LT1
Sep 14, 2010 04:18 AM
jwlee7ucla
Aug 7, 2007 03:48 PM
mr 636
Mar 26, 2006 08:35 PM
honda4life4456
Nov 16, 2003 06:20 AM
