LS/VTEC running horrible and shooting smoke!
Old Jan 27, 2010 | 10:23 PM
InTheLBC20's Avatar
Default LS/VTEC running horrible and shooting smoke!
As the title suggests, my ls/v is shooting mad smoke and sounding like a suburu. I haven't been getting on it, as it is my daily driver. My water pump went out about a week and 3 days ago! Since I've replaced the belt and pump, it's been running funny and it overheated twice earlier today. Like I said, this is my daily driver and I have no idea what would have caused this to happen. Out of the blue this happened tonight with no warning. Any input is welcomed, as I need to get this thing back on the road as soon as possible. Although I think I need to be sourcing a new engine so I can rebuild the the bottom end of my beast ASAP. Anyways that is my plan...but if anyone has any input for a quick fix I'm all ears!
Old Jan 27, 2010 | 10:25 PM
.Manny.'s Avatar
Touching My Member
Default Re: LS/VTEC running horrible and shooting smoke!
check to see that you put the timing belt on correctly first. then leakdown to see where the problem is.
Old Jan 27, 2010 | 10:48 PM
nycpatron's Avatar
most likely its out of time
Old Jan 27, 2010 | 11:57 PM
DCRB's Avatar
sounds like a blown head gasket. mine did the same thing, and the headgasket was blown on my car. check for the usual stuff. low compression in two (or more) cylinders, bubbles comming out of the radiator neck, sweet smelling exhaust, milkshake for oil.
Old Jan 28, 2010 | 12:03 AM
.Manny.'s Avatar
Touching My Member
the leak down will rule out a blown head gasket rather quickly.
Old Jan 31, 2010 | 06:16 PM
InTheLBC20's Avatar
Well, after I removed the head I found out that the head gasket blew around the inside of number 4 cylinder on the exhaust side. I ordered some ARP head studs that should be here within a couple days and already have my replacement head gasket. It only had stock head bolts and I think that was the contributing factor to the head gasket failing. I'll let you guys know how it goes...
Old Jan 31, 2010 | 06:29 PM
beansandrice's Avatar
Glad your getting it fixed. The arp head studs are awesome.
Old Jan 31, 2010 | 06:49 PM
crx_si-r's Avatar
there is nothing wrong stock head bolts, i have been running them on my LSV for the last couple years. BUT, mine were all bought new from honda/acura, if they were used then i could see it possibly contributing to the problem.
Old Feb 1, 2010 | 11:37 AM
InTheLBC20's Avatar
Yeah, if I put the motor together I would have put ARPs in from the get-go, but I bought it from a friend of mine. I asked him if the bolts were used or not, he said he didn't know so whatever. I figure since its torn down anyways might as well beef it up a little with some ARPs. I can't wait for 'em to get here!
prettylew
26
Jul 27, 2009 01:20 PM
HondaRexBoi
12
Aug 5, 2007 11:18 AM
88hatchef
Jan 1, 2007 07:07 AM
GsrTurboCRX88
Jun 5, 2006 07:44 AM
JDMvtecDRAGSTA
Aug 1, 2002 05:19 PM
