imput on my build
ive been doing some research and i'm just looking for a little imput.
-Daily driven stock sleeve ls block.
-stock ls crank
-crower maxi-light rods
-pistons(12.1-12.7) je or wiseco
-oem bearings
-z10 gridle
-00b16 head(stock porting)
-has full skunk2 valvetrain but im thinking of going with rocketmotorsports cams/valvetrain. maybe the m22 cams
-oem headgasket
-arp studs
-have a type r mani now thinking of getting a edelbrock
-65mm throttle body
im really just not sure what cams and manifold to go with
-stock ls crank
-oem bearings
-z10 gridle
-oem headgasket
-arp studs
-65mm throttle body
How can we give you input when you have told us almost nothing we can use to evaluate your parts list?
- what's your budget?
- what is your power goal?
- how will the car be used (DD, track?)
- how important is reliability?
Help us help you.
Help us help you.
i said its a daily. pump gas. i have time to build it so the budget is pretty high. thats why i choose 700rods. im not sure on a power goal because at the moment im leaving the head with stock ports so i know ill be limited.
MikeD21
26
Mar 17, 2018 06:03 AM
Maciel
26
Mar 20, 2017 10:32 AM
dan's integra
15
Jan 16, 2007 07:17 PM
